You see the plug, but the numbering is from the OBD connector socket NOT
The number in red is correct by Mattydr67
use this and you have the correct pinout
greeting
osmangdk
Post by osmangdk »
hi,everyone.
OK. Well, what do I solder the pins.
thanks.
That depends on which vehicle!
If it is an Alfa 147 and 159, you only need to pin 1, 7, 12 connect.
This interface should not apply to the Mito, Grande Punto, 500 and so on.
And note the pin numbers (red) which has given you mattydr67
osmangdk
Post by osmangdk »
thank you for everything.
Alba_Skye
Post by Alba_Skye »
So did anyone come up with a solution to make the 'ELM327-USB V3.0' Work yet?
Soldering and removing R04 does not work with this layout?
photo(5) (Custom).JPG (31.53 KiB) Viewed 12216 times
photo(4) (Custom).JPG (44.17 KiB) Viewed 12216 times
fewleh
Post by fewleh »
Hi, I have just hit this problem. Just wondering if I'm missing something, tried all sorts with my cable to get it open, but I can't.. What's the procedure for getting the casing open so I can see the chipset?
Thanks in advance, really hope I can get the cable working properly.
fewleh wrote:Hi, I have just hit this problem. Just wondering if I'm missing something, tried all sorts with my cable to get it open, but I can't.. What's the procedure for getting the casing open so I can see the chipset?
Take off the label (on the label is written ELM327 interface - Supports all OBDII protocols) and under it you will find 4 holes with 4 screws...
Just unscrew them and that is it... ;) See the photo...
ELM 327.jpg (32.61 KiB) Viewed 12126 times
fewleh
Post by fewleh »
EXCELLENT :) Thanks... if only I knew it was that easy, before I smashed it all up :D
cendler
Post by cendler »
Alba_Skye wrote:So did anyone come up with a solution to make the 'ELM327-USB V3.0' Work yet?
I have the same problem, please help
rxsx
Post by rxsx »
Hello, I just wanted to thank you, i bought a Chinese-made ELM327 Bluetooth v1.5, had the same problem, only connected to ECU, now i desoldered R04 and all CAN systems work perfectly...
Thanks again, if it wasn't for you probably i'd have bought another interface...
