You see the plug, but the numbering is from the OBD connector socket NOT
The number in red is correct by Mattydr67
use this and you have the correct pinout
greeting
greeting
hi,everyone.
OK. Well, what do I solder the pins.
thanks.
thanks.
That depends on which vehicle!
If it is an Alfa 147 and 159, you only need to pin 1, 7, 12 connect.
This interface should not apply to the Mito, Grande Punto, 500 and so on.
And note the pin numbers (red) which has given you mattydr67
thank you for everything.
So did anyone come up with a solution to make the 'ELM327-USB V3.0' Work yet?
Soldering and removing R04 does not work with this layout?
- photo(5) (Custom).JPG (31.53 KiB) Viewed 12221 times
- photo(4) (Custom).JPG (44.17 KiB) Viewed 12221 times
Hi, I have just hit this problem. Just wondering if I'm missing something, tried all sorts with my cable to get it open, but I can't.. What's the procedure for getting the casing open so I can see the chipset?
Thanks in advance, really hope I can get the cable working properly.
Take off the label (on the label is written ELM327 interface - Supports all OBDII protocols) and under it you will find 4 holes with 4 screws...fewleh wrote:Hi, I have just hit this problem. Just wondering if I'm missing something, tried all sorts with my cable to get it open, but I can't.. What's the procedure for getting the casing open so I can see the chipset?
Just unscrew them and that is it...
- ELM 327.jpg (32.61 KiB) Viewed 12131 times
EXCELLENT
Thanks... if only I knew it was that easy, before I smashed it all up
I have the same problem, please helpAlba_Skye wrote:So did anyone come up with a solution to make the 'ELM327-USB V3.0' Work yet?
Hello, I just wanted to thank you, i bought a Chinese-made ELM327 Bluetooth v1.5, had the same problem, only connected to ECU, now i desoldered R04 and all CAN systems work perfectly...
Thanks again, if it wasn't for you probably i'd have bought another interface...
