elm327 can not working, what resistor should i remove?
nickromano
Post by nickromano »
i have this interface and i've changed those capacitors with 2 560pF but still won't work.
anyone can tell me what is the resistor between CAN L and CAN H that i need to remove from the pcb??
thanks!
Re: elm327 can not working, what resistor should i remove?
Why did you solder these capacitors?
And at what point?
In my opinion, your board is a resolder unnecessary
It is with this strain ELM interface, mostly by setting error
nickromano
can isn't working. maybe there is an unecessary resistor between can L and can H but i don't know what it is
These capacitors are not installed properly!
Just look at this thread again to
viewtopic.php?f=5&t=1493
Here is the layout of ELM Electronics' should be displayed where these capacitors and resistors.
But I have yet had no ELM327 these components soldered into the
are needed.
The resistance needs to be removed. MCP2551 is in front of the chip (6 +7)
soldered.
If this does not exist.
Must be removed no resistance.
Otherwise, the connectivity problem is due to drivers or settings of the COM ports
ELM v1.5 R04 entfernen.jpg (17.71 KiB) Viewed 6794 times
