stilo key fob
stilomark
stilo key fob
Post by stilomark »
hi .i have a problem my remote has stopped working .i can lock and unlock with the key .i thought it was the battery so i changed it but its still the same .the led flashes but not working .can anyone help?
Re: stilo key fob
I think you need to reprogram "remote control" on you key!
for this feature you need a CODE CARD!
I can not remember which module you need to connect (Body I think :roll: )...
but i know you need to go to "Adjustments" and you are going to see "remote control...."
just follow the instructions... ;)
derekwatt5
Re: stilo key fob
Post by derekwatt5 »
hi
did u ever get this to work?? i have the same problem!
bope
Re: stilo key fob
Post by bope »
Hi!
I have the same problem on my ALFA 147...the remote key battery is fully charged(3.2V), the led flashing when I push/hold the button...but I cant lock or unlock the doors...I tried to sync the remote with body computer, but when I have to hold a button more than 3sec after that i get message the battery low...what should I do?
Shadeyman
Re: stilo key fob
Post by Shadeyman »
bope wrote:Hi!
Try disconnecting the car battery for a couple of hours, over night perhaps. This will reset the ECU and in most cases reconfigures the fob settings allowing the remote locking and unlocking to function again.
Present Software
Multiecuscan v4.7 Registered
FES Dashboard
Present Cars
2011 FIAT 500 TwinAir
2011 VOLVO XC60
derekwatt5
Re: stilo key fob
hi
i tried this! but did not work??? :(
Re: stilo key fob
Try the new version of FES - the 2.7 version! It should work! I tested on Fiat Stilo 2001 and "remote control" worked perfectly! ;)
There was a bug in version 2.6.1! :roll:
derekwatt5
Re: stilo key fob
hi
how did you do it :shock: if you could give me a run down on what to do :oops:
thanks
Re: stilo key fob
derekwatt5 wrote:hi
thanks
Finally I got the time to explain you the procedure... ;) It is easy...
Select: Make>Model>System>Ecu
(in my case Fiat>Stilo>1.6 16V>Body>Marelli MF Body Computer - as shown on photo #1)
FES-key programming 1.JPG (62.3 KiB) Viewed 30396 times
Re: stilo key fob
After that go to: Adjustments>Remote Control Programming>READ the guidelines on the right box (at least 2-3 times) as shown on photo #2
After that click: Execute and the one small window will appear. Just enter 5 digit security number from you CODE CARD and program will ask you to press "lock/unlock" button on the key. After you press that button you will if you have more keys press Y and if you do not have press N.
Exit the program and wait for about 15-30 seconds! Your key has been programmed!
Cheers, ;)
FES-key programming 2.JPG (56.91 KiB) Viewed 30394 times
