stilo key fob
stilo key fob
hi .i have a problem my remote has stopped working .i can lock and unlock with the key .i thought it was the battery so i changed it but its still the same .the led flashes but not working .can anyone help?
Re: stilo key fob
I think you need to reprogram "remote control" on you key!
for this feature you need a CODE CARD!
I can not remember which module you need to connect (Body I think
but i know you need to go to "Adjustments" and you are going to see "remote control...."
just follow the instructions...
derekwatt5
Re: stilo key fob
hi
did u ever get this to work?? i have the same problem!
Re: stilo key fob
Hi!
I have the same problem on my ALFA 147...the remote key battery is fully charged(3.2V), the led flashing when I push/hold the button...but I cant lock or unlock the doors...I tried to sync the remote with body computer, but when I have to hold a button more than 3sec after that i get message the battery low...what should I do?
Re: stilo key fob
Try disconnecting the car battery for a couple of hours, over night perhaps. This will reset the ECU and in most cases reconfigures the fob settings allowing the remote locking and unlocking to function again.bope wrote:Hi!
Present Software
Multiecuscan v4.7 Registered
FES Dashboard
Present Cars
2011 FIAT 500 TwinAir
2011 VOLVO XC60
FES Dashboard
Present Cars
2011 VOLVO XC60
derekwatt5
Re: stilo key fob
hi
i tried this! but did not work???
Re: stilo key fob
Try the new version of FES - the 2.7 version! It should work! I tested on Fiat Stilo 2001 and "remote control" worked perfectly!
There was a bug in version 2.6.1!
derekwatt5
Re: stilo key fob
hi
how did you do it
if you could give me a run down on what to do
thanks
how did you do it
thanks
Re: stilo key fob
Finally I got the time to explain you the procedure...derekwatt5 wrote:hi
how did you do itif you could give me a run down on what to do
thanks
Select: Make>Model>System>Ecu
(in my case Fiat>Stilo>1.6 16V>Body>Marelli MF Body Computer - as shown on photo #1)
- FES-key programming 1.JPG (62.3 KiB) Viewed 30400 times
Re: stilo key fob
After that go to: Adjustments>Remote Control Programming>READ the guidelines on the right box (at least 2-3 times) as shown on photo #2
After that click: Execute and the one small window will appear. Just enter 5 digit security number from you CODE CARD and program will ask you to press "lock/unlock" button on the key. After you press that button you will if you have more keys press Y and if you do not have press N.
Exit the program and wait for about 15-30 seconds! Your key has been programmed!
Cheers,
Cheers,
- FES-key programming 2.JPG (56.91 KiB) Viewed 30398 times
