Palio 1.9D
Palio 1.9D
Dear Sir,
I have a Palio 1.9D in India and there are many other like me. similarly there are approx 4 to 5 other petrol engines
1.2 Palio Old
1.6 Palio Old
1.9 Palio Diesel Old (My car)
1.1 Palio Stile New
1.6 Palio Stile New
1.3 Palio Multijet Diesel New
To begin with Irequest you to kindly provide support for the ECU & ABS (Bosch) of 1.9D, as of now only Airbag is supported.
Thank you for making this software as till date people like me were at the mercy of local FIAT dealers, I'm in the process of purchasing a cable to enable me to run diagnostic tests for my ABS (not functioning & light indicating in my instrument cluster& no help from local FIAT dealership{they have actually told me that they can't repair my car and to take it to some other workshop, when there is only one dealership in Goa})
Regards
Rahul Dev
Goa, India
1.2 Palio Old
1.6 Palio Old
1.1 Palio Stile New
1.6 Palio Stile New
Regards
Rahul Dev
Goa, India
Re: Palio 1.9D
Dear Yani,
I have been able to take photos of the Palio 1.9D ECU in my car. It is 2003 model and there are lots of numbers written on it. Please find the enclosed photos and tell me the ECU Model.
I'm working on finding the model of the ABS and only Bosch is written on it, I will revert ASAP.
Please let me know if you need any other details.
Regards
Rahul Dev
Regards
Rahul Dev
- Pic 2
- Palio 1.9D ECU India 02_1.JPG (27.74 KiB) Viewed 10740 times
- Pic 1
- Palio 1.9D ECU India 01_1.JPG (33.03 KiB) Viewed 10741 times
Re: Palio 1.9D
the ECU modle number is
LUCAS DCU3F EEPROM 25/95080
Re: Palio 1.9D
I have the same pump in punto II 1.9D. Please support the pump in my car. In Poland there are a lot of these cars.
- Schowek-b.jpg (44.95 KiB) Viewed 10663 times
- Schowek-a.jpg (31.23 KiB) Viewed 10662 times
- Schowek-1.jpg (39.33 KiB) Viewed 10679 times
Re: Palio 1.9D
Your ECU is on my TO DO list... Will incluse it in the future versions.
Re: Palio 1.9D
i'm also interested in support for this ECU, i have it on a mk2 punto 1.9d
Re: Palio 1.9D
Dear Yani,
thank you very much for your kind words, i'm eagerly looking forward to your updates, if you need any thing to be done for you, like data mining etc. please let me know.
Thank you once again.
Re: Palio 1.9D
I am having same Palio 1.9 D and I guess the same ECU will be there in my car. I am waiting for the software so that I can check my car as its giving me trouble of poor ignition. I would also like to know how do I get the cable for this ECU.
Harsh
Harsh
Re: Palio 1.9D
I was able to connect to the ECU punto 1.9D. It works with cable LM327. You can erase mistakes. You can see part of the parameters. However, the scale is inappropriate. Actuators do not work. Please support this Lucas ECU. The following screenshots.
Here is some documentation for Lucas EPIC dynamic parameters, errors and other things. It may be helpful? Pump out is identical.
Re: Palio 1.9D
Good evening Gentlemen.One more question regarding Lucas Injection ECU from a beginner.Is it possible to connect a KKL interface to this injection control unit or only LM 327 is able.Thank you in advance for your advices
