Palio 1.9D
outpass
Palio 1.9D
Post by outpass »
Dear Sir,
I have a Palio 1.9D in India and there are many other like me. similarly there are approx 4 to 5 other petrol engines
1.2 Palio Old
1.6 Palio Old
1.9 Palio Diesel Old (My car)
1.1 Palio Stile New
1.6 Palio Stile New
1.3 Palio Multijet Diesel New
To begin with Irequest you to kindly provide support for the ECU & ABS (Bosch) of 1.9D, as of now only Airbag is supported.
Thank you for making this software as till date people like me were at the mercy of local FIAT dealers, I'm in the process of purchasing a cable to enable me to run diagnostic tests for my ABS (not functioning & light indicating in my instrument cluster& no help from local FIAT dealership{they have actually told me that they can't repair my car and to take it to some other workshop, when there is only one dealership in Goa})
Regards
Rahul Dev
Goa, India
outpass
Re: Palio 1.9D
Post by outpass »
Dear Yani,
I have been able to take photos of the Palio 1.9D ECU in my car. It is 2003 model and there are lots of numbers written on it. Please find the enclosed photos and tell me the ECU Model.
I'm working on finding the model of the ABS and only Bosch is written on it, I will revert ASAP.
Please let me know if you need any other details.
Regards
Rahul Dev
Pic 2
Pic 2
Palio 1.9D ECU India 02_1.JPG (27.74 KiB) Viewed 10744 times
Pic 1
Pic 1
Palio 1.9D ECU India 01_1.JPG (33.03 KiB) Viewed 10745 times
outpass
Re: Palio 1.9D
Post by outpass »
the ECU modle number is
LUCAS DCU3F EEPROM 25/95080
rex
Re: Palio 1.9D
Post by rex »
I have the same pump in punto II 1.9D. Please support the pump in my car. In Poland there are a lot of these cars.
Re: Palio 1.9D
Your ECU is on my TO DO list... Will incluse it in the future versions.
smokeme
Re: Palio 1.9D
Post by smokeme »
i'm also interested in support for this ECU, i have it on a mk2 punto 1.9d 8-)
outpass
Re: Palio 1.9D
Post by outpass »
Dear Yani,
thank you very much for your kind words, i'm eagerly looking forward to your updates, if you need any thing to be done for you, like data mining etc. please let me know.
Thank you once again.
harshl
Re: Palio 1.9D
Post by harshl »
I am having same Palio 1.9 D and I guess the same ECU will be there in my car. I am waiting for the software so that I can check my car as its giving me trouble of poor ignition. I would also like to know how do I get the cable for this ECU.
Harsh
rex
Re: Palio 1.9D
Post by rex »
I was able to connect to the ECU punto 1.9D. It works with cable LM327. You can erase mistakes. You can see part of the parameters. However, the scale is inappropriate. Actuators do not work. Please support this Lucas ECU. The following screenshots.
blad pompy2.jpg (120.82 KiB) Viewed 10306 times
blad pompy.jpg (106.72 KiB) Viewed 10298 times
Here is some documentation for Lucas EPIC dynamic parameters, errors and other things. It may be helpful? Pump out is identical.
EpicServiceManual.pdf
Epic Service Manual
(511.47 KiB) Downloaded 788 times
catarad
Re: Palio 1.9D
Post by catarad »
Good evening Gentlemen.One more question regarding Lucas Injection ECU from a beginner.Is it possible to connect a KKL interface to this injection control unit or only LM 327 is able.Thank you in advance for your advices
