ELM 327 1.3 can line problem
ivica21
Post by ivica21 »
Today i received my fourth elm327 1.3 and can line not work.I dont know what is the problem.I use registered version of fiatecu.
ELM327 v 1.4
Jerry 159
Re: ELM 327 1.3 can line problem
Post by Jerry 159 »
I have the bottom interface, and its working OK for me.
Have you installed the driver and selected the right comport?
ivica21
Post by ivica21 »
Yes.I instaled drivers and select port and baudrate.What version of drivers you have?
I can conect to engine but dashboard and service reset not work.
ELM327 v 1.4
ivica21
Post by ivica21 »
When i plug in car Blue interface, lamp for petrol is blinking.Maybe the wires in interface not corectly soldered.
ELM327 v 1.4
ivica21
Post by ivica21 »
Today i received my 5-th elm327 with original 1.4 ic from skpang.Only this work perfect with can line.Other 4 elm327 1.3a from china is defected or bad clone. :?
ELM327 v 1.4
mattydr67
Post by mattydr67 »
I opened up my interface and I looked.
I have the bottom blue one.
The soldering are the same like your.
TribesMan
Post by TribesMan »
Mine is also the same as the bottom one... works OK.
ivica21 wrote:Today i received my 5-th elm327 with original 1.4 ic from skpang.Only this work perfect with can line.Other 4 elm327 1.3a from china is defected or bad clone. :?
just one question: where did you bought this interface? eBay or??? :roll:
ivica21
Post by ivica21 »
Yes from ebay and china.Only original elm327 from skpang works fine.Today i solder elm327 1.4 ic on interface from Serbia and k-line and can line works fine.
ELM327 v 1.4
many thanks for this info! ;)
do you by any chance have eBay link from skpang?
cheers mate
