Fiat Doblo radio change vp1 to vp2
Evron2
Re: Fiat Doblo radio change vp1 to vp2
Post by Evron2 »
Hi, This is it
abarthmultijet
Post by abarthmultijet »
Can you copy paste the code please, it is much easier for everyone
Evron2
Post by Evron2 »
30 38 32 35 30 32 32 35 37 34 30 4F 55 54 50 55 54 44 4A 49 54 20 15 06 17 4B 00 00 04 11 00 00 00 09 00 00 04 11 00 00 00 11 40 53 08 20 00 7C 20 00 00 00 2E 00 00 00 8C 06 0B 02 60 C0 0A 50 00 05 00 05 04 00 00 00 00 57 00 00 00 00 12 10 12 03 21 11 00 FF 00 04 00 80 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 01 00 00 85 12 00 14 00 00 00 44 00 00 00 00 00 00 00 00 0E 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 1F 00 00 3B 00 00 02 FF
Ah,got it now,hope this helps plz ;-) ;-)
abarthmultijet
Do you know how to run an proxy allignment? Try doing that with the existing code.
Evron2
Post by Evron2 »
Hi tried that a few times,even if the radio is disconnected it fails.
Ive changed byte 121 to 44 from 40 as suggested.I`ll do it again tomoz and put the result on.
Many thanks Evron
Evron2
Post by Evron2 »
Hers what it says ;-)
radio faultmm.jpg (4.4 MiB) Viewed 31510 times
abarthmultijet
Try to change 123 in 05,
With or without change of 121.
eggy43
Post by eggy43 »
I'm trying to do this change too (albeit on a Ducato van!)
How do you apply the edited PA file? I've saved it to notepad for safe keeping before modifying but not sure how to apply the changes
My log seems to suggest that I need to change Byte 123 from F6 to F4 (Entertainment Telematic Node - Request out of range)
Any help would be much appreciated :-)
abarthmultijet
eggy43 wrote: 28 Dec 2024, 15:28 I'm trying to do this change too (albeit on a Ducato van!)
If you are in the Proxy allignment tab, highlight the PROXY ALIGNMENT PROCEDURE (pre selected by default) and press execute in the right bottom corner.
eggy43
Post by eggy43 »
abarthmultijet wrote: 28 Dec 2024, 18:14
Is that after editing the byte screen? (Sorry, I'm very new to this and can't afford to screw it up and have the van off the road!) :D
