Fiat Doblo radio change vp1 to vp2
Fiveo
Post by Fiveo »
I have a problem with radio retrofit in my ”16 Fiat Doblo. Factory it have radio Continental VP1, i bought used one 5’ Uconnect VP2 ECE DAB NAV RVC and aftermarket reverse camera. After install, almost everything in radio works exclude time/data change, in engineering menu almost everything is not light up, mileage blink, and reverse camera(i install it to correct pins) doesnt work. When i put reverse gear nothing happens.
I try to do Proxi alignment but unsuccesfull. There is a problem with telematic node
GPS/DAB antena ll be installed later
I think new radio is not recognized, what in MES i can change it for correct one/activate reverse camera and repair proxy alignment?
Big thx for help, a spend a lot of time read about it and nothing work :o
Fiveo
Re: Fiat Doblo radio change vp1 to vp2
Post by Fiveo »
My doblo is ’16 model, radio unit is VP2Refresh with production date 28.07.2018 like on a picture. From 2018 everything works behind SGW- maybe some problem with that?
Thats my config for now
4B 10 00 05 10 00 00 00 4B 10 00 05 10 00 00 00 41 00 00 00 10 00 00 00 01 00 00 00 10 00
4B 10 00 05 10 00 00 00 09 00 00 04 10 00 00 00 4B 10 00 05 10 00 00 00 09 00 00 04 10 00
33 36 32 36 33 31 33 35 35 30 35 4F 55 54 50 55 54 44 4A 49 54 20 15 12 30
4B 10 00 05 10 00 00 00 09 00 00 04 10 00 00 00 85 40 73 07 7B 00 00 30 80
20 00 16 00 1E 00 00 06 0B 02 46 C0 0A 50 08 09 10 05 04 08 00 80 00 60 00
00 00 00 54 03 43 01 00 22 00 00 00 21 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 9D 00 94 00 01 00 00 82 12 37 20 00 00 00 B0 00 04 00 00
00 00 00 00 01
abarthmultijet
Post by abarthmultijet »
Very interested in the solution, I want to do the same to my Doblo.
chrener
Post by chrener »
Hi guys
Try to change byte 111 to 02
And sometimes it needs extend proxi lenght up to 235 or 250 bytes ( depend on radio SW version)
good luck!
Fiveo
Post by Fiveo »
chrener wrote: 20 Apr 2024, 13:16 Hi guys
good luck!
Thank you! It work :) I change byte to 02, and extend Proxi to 250bytes. Proxi align success without errors, odo stop blinking! 8-)
Camera activated using alfaObd, but when i put rear gear-screen is change to blank, and info „camera system-not available”
Installed to wrong pins or what? Camera is aftermarket from Aliex
Edit:
Finally… it work! :D It was some problem with cables in china camera🥹
abarthmultijet
My original code was
33 36 32 36 33 31 35 30 35 37 34 4F 55 54 50 55 54 44 4A 49 54 20 15 04 22 6B 10 00 05 00 00 00 00 29 00 00 04 00 00 00 00 A5 C0 77 07 7B 00 00 30 A0 10 00 46 00 1E 00 80 06 0C 03 3C C0 8A 50 08 01 10 05 04 08 00 80 00 60 00 00 00 00 51 03 53 01 00 22 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8C 00 94 04 01 00 00 82 12 37 20 00 00 00 30 00 00 00 00 00 00 00 00 01
Ended up changing to code below and car accepts code and no more blinking of milage!
33 36 32 36 33 31 35 30 35 37 34 4F 55 54 50 55 54 44 4A 49 54 20 15 04 22 4B 10 00 05 10 00 00 00 29 00 00 04 00 00 00 00 A5 C0 77 07 7B 00 00 30 A0 10 00 46 00 1E 00 80 06 0C 03 3C C0 8A 50 08 01 10 05 04 08 00 80 00 60 00 00 00 00 51 03 53 01 00 22 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8C 00 94 04 02 00 00 82 12 37 20 00 00 00 30 00 05 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Evron2
Post by Evron2 »
Hi could anyone tell me where to get the "byte" plan from to change my VP1 to a VP2 in a 2016 boxer van plz
abarthmultijet
Evron2 wrote: 07 Nov 2024, 19:33 Hi could anyone tell me where to get the "byte" plan from to change my VP1 to a VP2 in a 2016 boxer van plz
Go to Body tab, -> CAN Setup / PROXY Alignment Procedure -> Adjustments -> Then press control+alt+c
There you find code. Before any change save the current code, i use Windows notepad for proxy codes.
Evron2
Post by Evron2 »
Hi thanks,I can find my "bytes" these are for a VP! that was in originaly.theres 250 bytes ending in 3b 00 00 02 ff
I wondered where to get a new set compatable with a VP2 to replace them ?
The VP2 works ok but I can`t get the mileage to stop flashing :-(
abarthmultijet
Can you upload your full proxy code?
