carplay doesn't start
carbox
Post by carbox »
Inquiry from Japan
The 2017 European FIAT500 has been changed from 5 inches to 7 inches UCONNECT.
I adjusted the custom proxy alignment, but Apple CarPlay does not work.
Please tell me the correct proxy.
Kind regards
Below is the current proxy.
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 70 00 81 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
carbox
Re: carplay doesn't start
Post by carbox »
Thank you for your support,abarthmultijet
The new proxy I received had too many bytes to complete.
I checked and set it to 193byte, but carplay does not start.
The current proxy is below.
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 81 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Please help me
carbox
Post by carbox »
UCONNECT7 itself was a car play compatible product.
davidino66
Post by davidino66 »
Are you sure that uconnect have carplay?? same 7 inch versions dont have that function
budgoz
Post by budgoz »
carbox wrote: 29 Aug 2024, 08:00 Hello
Inquiry from Japan
Kind regards
Hey,
can you also paste your original proxy?
Anyway here a few proxy to try:
n.1
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C7 75 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 70 00 91 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
n.2
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 75 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 70 00 91 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
n.3
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 75 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 91 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Good luck and let us know!
carbox
Post by carbox »
00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
193byt
Thanks for the advice and some proxies.
The above is the first proxy listed in the report.
First, I set it to JAPAN, then changed from 5 inch to 7 inch UCONNECT.
Of the three proxies I received, 200byte, 201byt, and 187byte all resulted in ETM errors.
There are also corrections.
Please check the image.
Please tell me about the new proxy. Is 148 bytes the display size? 157byte is car play? Is that so?
Even after setting, CARPLAY will not start.
Please help me
Kind regards
carbox
Post by carbox »
This is an image of the proxy I received.
Thank you.
n3 187byt
n3 187byt
n2 201byt
n2 201byt
n1 200byt
n1 200byt
budgoz
Post by budgoz »
carbox wrote: 02 Sep 2024, 12:26
I dont understand this part, all three the proxys I gave you are 193 bytes long. Are you sure you are pasting them correctly?
carbox wrote: 02 Sep 2024, 12:26 Please tell me about the new proxy. Is 148 bytes the display size? 157byte is car play? Is that so?
If the ETM allignment fails then the new configuration is not loaded and so the Carplay doesn't work. You need to get the SUCCESS message during the ETM allignment.
Anyway let's start over from your oroginal proxy, try this one:
n. 4
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 91 00 0F 00 00 00 00 05 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 D1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
It must be exactly 193 bytes long, no blank spaces anywhere.
Start the allignment and post what errors you get.
budgoz
Post by budgoz »
Some other attempts to try:
n.5
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 11 00 0F 00 00 00 00 05 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
n.6
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 15 00 0F 00 00 00 00 05 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
n.7
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 44 00 11 00 0F 00 00 00 00 05 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
n.8
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 44 00 15 00 0F 00 00 00 00 05 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
carbox
Post by carbox »
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 11 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Thanks for the advice and useful information.
The above proxy worked fine this time as well.
Car play started on the n4 proxy, but the odometer flashed due to an error in the additional heater.
based on n8
byte148 08→05
byte123 15→11
byte130 05→01
Changed to.
The odometer turned on and the car play started.
thank you for your help
