carplay doesn't start
Inquiry from Japan
The 2017 European FIAT500 has been changed from 5 inches to 7 inches UCONNECT.
I adjusted the custom proxy alignment, but Apple CarPlay does not work.
Please tell me the correct proxy.
Kind regards
Below is the current proxy.
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 70 00 81 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Inquiry from Japan
Kind regards
Re: carplay doesn't start
Thank you for your support,abarthmultijet
The new proxy I received had too many bytes to complete.
I checked and set it to 193byte, but carplay does not start.
The current proxy is below.
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 81 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Please help me
Please help me
- IMG_5738.JPG (5.79 MiB) Viewed 6344 times
UCONNECT7 itself was a car play compatible product.
- IMG_5679.JPG (1.91 MiB) Viewed 6338 times
- IMG_5695.JPG (2.21 MiB) Viewed 6338 times
davidino66
Are you sure that uconnect have carplay?? same 7 inch versions dont have that function
Hey,carbox wrote: ↑29 Aug 2024, 08:00 Hello
Inquiry from Japan
Kind regards
can you also paste your original proxy?
Anyway here a few proxy to try:
n.1
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C7 75 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 70 00 91 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
n.2
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 75 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 70 00 91 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
n.3
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 75 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 91 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Good luck and let us know!
00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
193byt
Thanks for the advice and some proxies.
The above is the first proxy listed in the report.
First, I set it to JAPAN, then changed from 5 inch to 7 inch UCONNECT.
Of the three proxies I received, 200byte, 201byt, and 187byte all resulted in ETM errors.
There are also corrections.
Please check the image.
Please tell me about the new proxy. Is 148 bytes the display size? 157byte is car play? Is that so?
Even after setting, CARPLAY will not start.
Please help me
Kind regards
193byt
Please help me
Kind regards
This is an image of the proxy I received.
Thank you.
Thank you.
- n3 187byt
- IMG_5775-min.JPG (2.89 MiB) Viewed 5990 times
- n2 201byt
- IMG_5773-min.JPG (3 MiB) Viewed 5990 times
- n1 200byt
- IMG_5770-min.JPG (3.35 MiB) Viewed 5990 times
I dont understand this part, all three the proxys I gave you are 193 bytes long. Are you sure you are pasting them correctly?
If the ETM allignment fails then the new configuration is not loaded and so the Carplay doesn't work. You need to get the SUCCESS message during the ETM allignment.
Anyway let's start over from your oroginal proxy, try this one:
n. 4
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 91 00 0F 00 00 00 00 05 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 D1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Start the allignment and post what errors you get.
Some other attempts to try:
n.5
n.6
n.7
n.8
n.5
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 11 00 0F 00 00 00 00 05 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Code: Select all
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 15 00 0F 00 00 00 00 05 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Code: Select all
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 44 00 11 00 0F 00 00 00 00 05 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Code: Select all
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 44 00 15 00 0F 00 00 00 00 05 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00Re: carplay doesn't start
33 32 31 35 30 30 33 34 36 33 37 4F 55 54 50 55 54 44 4A 49 54 20 17 11 09 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C7 77 06 DB 00 1C C0 00 00 00 16 00 01 08 94 06 41 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 11 00 0F 00 00 00 00 01 80 40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Thanks for the advice and useful information.
The above proxy worked fine this time as well.
Car play started on the n4 proxy, but the odometer flashed due to an error in the additional heater.
based on n8
byte148 08→05
byte123 15→11
byte130 05→01
Changed to.
The odometer turned on and the car play started.
thank you for your help
based on n8
byte148 08→05
byte123 15→11
byte130 05→01
Changed to.
