Alfa Giulietta cannot calibrate Xenon Headlights
Ruggero1912
Post by Ruggero1912 »
Good morning everyone.
I have an Alfa Giulietta 2.0 with original Xenon Headlights pack.
I noticed that the beam lights are facing too downwards.
For this reason I tried to calibrate the Xenon unit from MES, but it returns me an error, even though I placed the Giulietta in the required conditions (flat surface, no one in the car, low beams turned on).
In the following image I reported a screenshot showing the values read from MES.
I have the doubt that the pitch is not correct, but I am not sure about that, what is considered a correct value when the car is on flat ground?
Do you know what component could cause wrong measurements of this value?
Thanks for your attention
shpuncik
Re: Alfa Giulietta cannot calibrate Xenon Headlights
Post by shpuncik »
check sensors physically if they are OK. voltages don't look correct.
Ruggero1912
shpuncik wrote: 29 Aug 2024, 14:11 check sensors physically if they are OK. voltages don't look correct.
Thanks, I will check it
Ruggero1912
Hi, many months have passed, but still I did not managed to calibrate the sensors.
I bought a new front side sensor online, waited for it and installed it, but now from MES I read a voltage value of about 5 volts for the front sensor.
I am not sure if it is an hardware or a software fault...
Do someone has the right impedance values for the sensors? So that I can compare with the ones that I can measure from mines.
Hope that this is not off-topic, but I really did not managed to find this information and in general infos related to this procedure.
shpuncik
Post by shpuncik »
Ruggero1912 wrote: 26 Jan 2025, 21:52 Hi, many months have passed, but still I did not managed to calibrate the sensors.
voltages for rear/front should be similar.
5V looks like either dead sensor or not plugged properly. in your first post front sensor voltage of ~0.5V is way to low - either bad sensor or adjusting arms are bent/broken.
Ruggero1912
Thank you very much for your reply.
However I was wondering if someone knows the pin out of the headlight pitch sensor and the expected impedance values on the pins, so that I can verify the ones from my unit.
However I did not manage to find any schema online, do someone knows where I could find it?
Thanks again
