Ducato 250 Gearbox
Jo_Neu
Ducato 250 Gearbox
Post by Jo_Neu »
I installed a new engine and gearbox in the Ducato 250 3,0 Multijet 180 from 2013.
Since then, the cruise control no longer works in 4th and 6th gear!
There is probably a different translation in the manual gearbox (6th gear) than that stored in the ECU.
Can this be adjusted with MES? How and where can I do that?
Would be great if you can help me.
chrener
Re: Ducato 250 Gearbox
Post by chrener »
What setup was originally in your car?
Original gearbox code and current gearbox code?
Year of production?
Jo_Neu
Post by Jo_Neu »
chrener wrote: 02 Apr 2022, 05:43 What setup was originally in your car?
Year of production?
i dont now that. The car is from 2013 and it was a original Gearbox
Jo_Neu
Post by Jo_Neu »
...its great here.............
abarthmultijet
Post by abarthmultijet »
Go to engine and adjustments, reset self learned functions. This may help.
Also try to change the gearbox type in the proxy allignment tab at the body tab.
Jo_Neu
Post by Jo_Neu »
abarthmultijet wrote: 08 Apr 2022, 18:42 Go to engine and adjustments, reset self learned functions. This may help.
ok, but where do i have to change something?
what type should i set?
now is type "DDTC"
what types are there on the Ducato?
in the software there are type 1, type 2, type 3 etc.
abarthmultijet
Maybe try them al. Don't know which one to use
shpuncik
Post by shpuncik »
post your FESLog with CAN Configuration info and proxi for comparison
Danko
Post by Danko »
Hi, I have very similar problem. Have you managed to solve it and how?
