I installed a new engine and gearbox in the Ducato 250 3,0 Multijet 180 from 2013.
Since then, the cruise control no longer works in 4th and 6th gear!
There is probably a different translation in the manual gearbox (6th gear) than that stored in the ECU.
Can this be adjusted with MES? How and where can I do that?
Would be great if you can help me.
Ducato 250 Gearbox
Re: Ducato 250 Gearbox
What setup was originally in your car?
Original gearbox code and current gearbox code?
Year of production?
Year of production?
...its great here.............
abarthmultijet
Go to engine and adjustments, reset self learned functions. This may help.
Also try to change the gearbox type in the proxy allignment tab at the body tab.
ok, but where do i have to change something?abarthmultijet wrote: ↑08 Apr 2022, 18:42 Go to engine and adjustments, reset self learned functions. This may help.
what type should i set?
now is type "DDTC"
what types are there on the Ducato?
in the software there are type 1, type 2, type 3 etc.
abarthmultijet
Maybe try them al. Don't know which one to use
post your FESLog with CAN Configuration info and proxi for comparison
Hi, I have very similar problem. Have you managed to solve it and how?
