Hello !
I'm a new user of Multiecuscan and I'm French.
I have a FIAT 500 1.3 (gasoil) and I've a problem.
I connect my PC with ELM327 USB at the car with yellow connector.
But when I click "Connect", the PC says the PORT COM is not accessible, or not open ...
Do you know what is the problem ? I don't know if my driver is good, where I can download the good driver ? (Windows10)
Sorry for my bad English
Martin
PORT COM with ELM327
Re: PORT COM with ELM327
Hello Martin
The Driver if you need is this one
And controlling again the the same comports be used
In Control Panel, as well as in the MES settings
Edit:
Oh, and for the engine control, ABS, steering no yellow adapter is needed
Edit:
Hello Eddy !
Thanks for you reply
, I test that tomorrow !
Martin
Martin
Hello !
I have download and install the good driver, and now, i have this error (in attachments)
Hi !
I see this viewtopic.php?f=5&t=1493&start=10#p3808, and I have the same :'(
I have to open it and make changes? is it easier to buy another that works without "hacking"?
Martin
Martin
Hello !
I change the driver and I have this screen : all is OK.
But when i connect the car at the ELM327, my pc have blue screen with "Kernel Secutity Check Failure"
Complicated Mulecuscan ...
Martin
Martin
- interfaceOK.png (10.25 KiB) Viewed 12357 times
Hello !
It's good ! I found the good driver, and now, I can connect my car with elm327.
But when I want to connect "Services", MES want I connect the yellow adaptator. When I connect it, MES say he can't connect the car.
Can I open the adatator for check the connections ? How "open" it ?
Martin
Martin
What "good" drivers have you found?
It could have built only a chip from Silicon Laps in laptop
otherwise the driver is I have linked the right
The yellow adapter you do not need to open, easy pins after
Compare Belegunsplan alongside Supported Vehicles
pin 6 to pin 1
pin 14 to pin 9
4 + 5 are the same
also pin 16 is also equal to
pin 6 to pin 1
pin 14 to pin 9
4 + 5 are the same
