Hello Juanito
Have you removed the resistor is the wrong one! :(
Not R04
You would need to remove the red marked resistance.
juanito
Post by juanito »
Alfaeddy wrote:Hello Juanito
Not R04
Hello Alfaeddy. Thanks for answers.
There's no red in the resistance of my elm.
andro58
Post by andro58 »
Ok, I'll try
Thanks again
Andrea
Not R04
Hello Juanito
I forgot one put the image, sorry
IMAG0391 markiert.jpg (379.78 KiB) Viewed 7013 times
juanito
Post by juanito »
Thanks for the answer but my problem is not finished
Ekran Alıntısı.JPG (95.04 KiB) Viewed 7006 times
Hello Juanito
Which Probelm?
There is but only, that is the proxy alignment OK.
And that is not necessary a realignment
And as I see yes you can also connect to the CAN setup produce.
So is your resistor problem no longer exists.
juanito
Post by juanito »
there is write proxy alignment is not needed. i cant execute proxy alignment procedure and i cant open cruise control light. thanks
Since I've read that right! :lol:
Why should a proxy alignment be done? ;)
If there is no need. !
That does not make sense, does it not?
arheu
Post by arheu »
Hello Eddy,
just got an Vgate Scan Bluetooth Advanced OBD Scan Tool but it connects only to the engine ECU.
Some pictures attached:
Please help me identify the resistor that should be removed.
Best regards!
Hello Arheu
Very good pictures!
So does the view joy :D
Which vehicle would you like to read?
When it comes to the often described here CAN bus problem
you should remove the red marked resitor
VgateScan-2 markiert.jpg (313.66 KiB) Viewed 6986 times
