FIAT PUNTO EVO - 2011
jln
Post by jln »
I change my motor oil, and i would like erase the red led "oil motor" from my dashboard.
I buy a Yellow cable and a Bluetooth "OBDII SCANNER". I remove a resistor between pin 6 and pin 14.
I have a ECU Communicaton problem.
Can you help me?
Re: FIAT PUNTO EVO - 2011
First of all go to Settings> Interface> Type of interface> select "ELM 327 v1.3+ (Bluetooth)"
Do not use your interface as OBD Key 1.40 (Bluetooth).
Second of all try to change speed. In the same window Settings> Interface> Speed> select "38400" speed and try.
In general speed 38400 is common speed for all cable interfaces and speed for BT interfaces iz 115200.
jln
Post by jln »
select "38400" .
Thanks you with these parameters, i can connect to ECU.
It's work good.
Now i have a another problem.
I make a service reset, but the red ligt is allows on my dashoard.
The service reset put 63768km in "DISTANCE AFTER LAST SERVICE".
I think i need to put 0km on this parameter? Yes - No?
If yes, In the Tab '"Adjustement i can't write this parameter?
How to resolve this issue.
OK! Here is solution.
When you are trying to reset OIL service light on ALL Italian diesel MJET cars you have to do next:
- select Engine > then "type of engine" > than F7 (settings) > then select "oil change version with DPF" > click F10 (execute);
- select service > than "service interval" > than F7 (settings) > then select "next service KM reset" > click F10 (execute).
You have to reset service message always on 2 separate ECUs. See photo.
MJET oil RESET.JPG (89.31 KiB) Viewed 10722 times
jln
Post by jln »
Thanks you for your help.
In Engine, I tried to execute "oil change version with DPF", but i have a error
Try with newer version of MES...
tomas
Post by tomas »
Interface> Speed> select "38400" speed and try. In general speed 38400 is common speed for all cable interfaces and speed for BT interfaces iz 115200.
Diablo 3 Gold
Buy Diablo 3 Gold http://www.diablo3fast.com/
