StiloTR
Post by StiloTR »
Hello Eddy..
Greetings From Istanbul...
I have 2003 Fiat Stilo 3 D...I bought ELM -327 (bluetooth) for my car...I can't use OBD..Bluetooht ok but I can't data read...
This is the picture...
Thanx...
Hello Stilo TR
Remove the red marked Resitor an your BT ELM Interface can read
CAN Bus with MES
GcMbX markiert.jpg (66.91 KiB) Viewed 9979 times
kosalepet
Post by kosalepet »
Hello Eddy . Greetings From Belarus...
I have 2007 Fiat Bravo . I bought ELM -327 (bluetooth) for my car...I can't use OBD..Bluetooht ok but I can't data read...
This is the picture... Sorry . I do not know English .
Hello Kosalepet
Thanks for the greetings :P
Your ELM interface has no disturbing resistor
it must work
check your
- Drivers
- Com port
- settings
IT must work
kosalepet
Post by kosalepet »
Hi Eddie. Thanks for the reply. I will connect. ;)
INR
Post by INR »
Hi, I possibly have the same problem but before modifying the ELM327 thought it worth checking.
By scanning for interface, the software identifies as K-line/VAG rather than ELM 327. If I manually select the ELM 327 interface it cannot find connection.
With the K-line/VAG interface type selected, there is "no response from ECU" (ignition is on)
First of all, what vehicle and year you want to read?
Because several people have already soldered on your ELM interface around
and it was not necessary
sgorchichko
Post by sgorchichko »
Hi guys,
Can you help me and tell me what to cut off on my ELM 237 v1.5a which I have recently received from China.
Here are photos of my cable.
The cable is connecting to engine ok but I can't reset service interval. There is no such item in the Adjustments tab.
2013-06-27 10.26.17 (Custom) (2).jpg (226.44 KiB) Viewed 9891 times
2013-06-27 10.26.05 (Custom) (2).jpg (254.84 KiB) Viewed 9891 times
Hello Skorchichko
I can not see what is under the white plastic.
Please remove this or make pictures in which this can be seen.
2013-06-27 10.26.17 (Custom) (2) markiert.jpg (145.93 KiB) Viewed 9891 times
sgorchichko
Alfaeddy wrote:Hello Skorchichko
Here you go!
2013-06-27 12.52.09 (Custom).jpg (215.33 KiB) Viewed 9892 times
