Hello Lolo85v
What can you read on your alfa 159
ECU ?
CAN setup ?
Body Comp ?
ABS ?
On the first side on this Thread is your ELM
and i think the v1.2 Chip cant read the Protokoll ISO 15765
v1.3 an later can this Protokoll read
Boris
Post by Boris »
Alfaeddy wrote:Hello
Yes I'm 95% sure, but doing is another picture of the part with 8 pins in addition to the resistor in the red frame
Here is the picture:
Hello Boris
This ist a nice picture :D
yes , remove R6 (121) and your Interface can read CAN Bus with Multiecuscan
Red frame in the last picture
lolo85v
Post by lolo85v »
lolo85v
Post by lolo85v »
Furthermore if I me connected to the engine I is none registration(inscription) to give
http://i69.servimg.com/u/f69/13/77/86/13/sans_t10.jpg
RESPONSE: ATZ
ELM327 v1.5a
ELM327 v1.5a
RESPONSE: ?
RESPONSE: ?
ello Lolo85v
Why are you still using the very old version Fiatecuscan 3.6?
try some Multiecuscan 1.3!
And with the free version you can only ECU and CAN make a connection info.
The only other controls with data base
Your interface test surprises me greatly?
because the normal manner on the interface described herein with the resistance problem pass this test without errors.
Unfortunately I can not at the moment be only the tip
try it again with MES 1.3
Hello Lolo85v
I just looked again your previous posts
and once detected, the ELM is not your v1.5.
But a v1.2
And as I have already written the v1.2 does not work well with Multiecuscan!
Therefore, your incomplete test display
Buy yourself another ELM and then your connection will work.
http://www.ebay.de/itm/260754573911?ssP ... 1423.l2649
lolo85v
Post by lolo85v »
Hello I have just made tests him(it) with the version 1.3 it is similar on previous post yes it was another elm I thus have to buy versions metal and that not function(office) always not
I is not of resistance r04 but r4.
Boris
Post by Boris »
Alfaeddy wrote:Hello Boris
I was playing with macro settings :-)
Alfaeddy wrote: yes , remove R6 (121) and your Interface can read CAN Bus with Multiecuscan
Works OK
Thanks!!!
:D
