Bluetooth Elm issues
saintetienne
Post by saintetienne »
Good evening everyone ,
I recently bought a bluetooth elm interface ( think it may be a 1.4 ) to access some info on my daughter's brera and reset oil message after I had serviced -it shows as connected and during tests pass all parts - however I can only get connection to main engine ecu - I had a brief look on here last night and say a post regarding removing a resistor to access can line , looked on here again tonight and can't find it - anyone know of this ?
thanks
Re: Bluetooth Elm issues
The others on ABS to control and xenon are all read by CAN bus, and to many ELM interface, a resistor must be removed.
Of the CAN bus signal interferes
For ABS and Xenon you need adapter cables or your ELM must be rebuilt.
The matter with the Resistor find more
viewtopic.php?f=5&t=1493
saintetienne
Hi Eddy ,
thanks for the reply - I have taken my interface apart and it looks quite different maybe cos it's a bluetooth one - do you think this can be modified or should I buy a better one ?
thanks
20130104_170151 (Small).jpg (141.95 KiB) Viewed 4633 times
20130104_170530 (Small).jpg (122.24 KiB) Viewed 4633 times
20130105_171540 (Small).jpg (152.19 KiB) Viewed 4631 times
Hello Saint Etienne
I marked in red the resistor to be removed .
Remove this and then your ELM also works in the CAN bus protocol
20130105_171540 (Small) markiert.jpg (152.02 KiB) Viewed 4627 times
saintetienne
I will do that tomorrow ,
many thanks
saintetienne
Eddy , thanks a million - up and running ! :D
Nice that I could help you :D
