Hi all,
can you please advise me how to set up the connection for VLinker FS.
I can't connect, Is it the same as OBDLink?
I still have HW not connected
Thx. Tom
Multiecuscan - VLinker FS
Re: Multiecuscan - VLinker FS
Connect your interface to a car and then to computer.
Run MES and push Settings / Interfaces / Scan For Interface...
You will see correct COM port number
Now Change Speed to 115200 and push Test button...
Jeep Renegade 1.4 MultiAir TURBO 75th Anniversary
hi guys, i am also new to this and wondering if vLinker FS USB will be 100% compatible with MES or not. I am about to get one. Appreciate your help. Cheers.hejzlar@seznam.cz wrote: ↑10 Jan 2023, 18:43 Hi all,
Thx. Tom
hi guys,
newbie here and exploring the MES for my Alfa Stelvio. I am about to get an USB interface that compatible to MES. vGate vLinker FS is the one I am looking at. Will it works? Thanks alot.
vGate vLinker FS Bluetooth with MES for iOS/iPhone
Also a newbie here, and pretty amazed, not in a good way, by the quality of the instructions, help and support for this product, however good the actual product itself may be.
To attempt to answer this specific question: I bought a vGate vLinker FS OBDII Bluetooth interface (Model CV304) and after some struggling I have got it to work with my Giulia. I am running MES on an iPhone 13 and iPad. I have not used the software in earnest yet, but the connection is working, I can read the data from my car, and I can access the tools to clear codes, reset service intervals and oil warning lights etc.
When setting up the iPhone to connect to the vLinker interface, it is important to chose the right 'Interface Type' setting, which are not particularly clear. I started with 'VGate BLE Bluetooth', but this did not work. I changed to 'OBDLink MX+/Vgate FS Bluetooth, and that worked.
Hope this helps.
Hope this helps.
