Proxy alignment procedure
Enrico_P92
Post by Enrico_P92 »
Goodmorning everyone,
I open this topic to ask for support as already on two vehicles I found it impossible to perform the proxi alignment procedure. Has this happened to other people before? I attach screen with error. The message is: EMPTY PROXI FILE IN BODY COMPUTER (BCM)
Thank's in advance
Re: Proxy alignment procedure
empty proxi is caused usually either by bad connection on car/adapter or configuration problems.
Enrico_P92
I tryed varius car and I have the same problem. Can you recommend me a method to solve the problem? I specify that the cars are both from the year 2021. I have used different swgw adapters but the problem remains. Could it be an OBD interface or software issue? do you have any advice to solve the problem? Precise that I have this problem only with recent cars and equipped with sgw
Tya,
Enrico
I've heared that not all SGW bypass devices cater for all the possible CAN-Hi, CAN-Lo and other signal lines.
Hopefully soemone here who has doen Proxi on an SGW equipped car can explain more and what bypass decvice they are using.
Enrico_P92 wrote: 30 Jan 2023, 09:32 Hi,
Tya,
Enrico
double check adapter settings and speeds under device manager and MES.
