I have the following question:
In the list of the SUPPORTED VEHICLES/SYSTEMS I can see, that for the Fiat
Ducato (type 250) Facelift the Tire Pressure Control (TPMS) Schrader (2/3 axle) is not supported.
Is there a chance that this feature will be implemented in the next Version of the “Multiecuscan” program?
The Version 4.8 I have already bought.
Gerd
Re: Ducato (type 250) Facelift
Unfortunately, the Ducato Facelift was not included in version 4.8 of Multiecusan.
Hi!
In MES is 3 versions of Ducato
1 - X250 2006-2009 with white BCM - without adapters
2 - X250FL (means facelift) 2010-2014 same body as X250 but with black BCM - with yellow adapter
3 - X290 body facelift 2014+ with black BCM - with yellow adapter
Newest ducato8 or X295 2021+ is unsupported yet but you can connect to BCM as Fiat TIPO... Proxialignment procedure is on your own risk...
Jeep Renegade 1.4 MultiAir TURBO 75th Anniversary
Hallo Chrener, many thanks for your hint.
But with my equipment I can’t access to Tipo. I have MES 4.9, EML 327 Interface and the yellow adapter.
Furthermore I wanted to change the value in the Tire Pressure Control and in the list of supported vehicles in non Tipo with a Tire Pressure Control.
I have actually same problem, with MES 4.9 and CANtieCar don't have access to a Ducato (with Pössl Caravan) ECU's.
On our Fiat 500e (California) everything is working fine
I have the same issue. I can connect to the BCM with AlfaOBD (without adapters) but not to other devices. Using MES SCAN, I can see some devices and also the BCM without adapters. With the yellow adapter I only see SAGEM Power Steering. I can connect to none with MES. I also have some model 2021 before the Ducato 8 was released. I thought about testing with the gray adapter. @chrener any update on your usage?chrener wrote: ↑16 May 2022, 11:20 Hi!
I got a little more information, it seems to be marketed internally as X295, Fiat Ducato MY2020. A bit frustrating that there is no information on the internet. I have no SGW installed. I found an alarm system which can be installed using an OBD adapter but for the Fiat Ducato MY2020, there is some custom adaption necessary, cf. https://www.campinglanghans.de/media/pdf/8a/55/d0/47490_einbauanleitung_1.pdf.
To me it seems that this particular model, shortly before the transition to Series 8 was made, has some yet to be explored changes regarding OBD and how systems can be read out.
Anyway, MES worked as expected. There was a wiring error in the CAN BUS. Three wires were linked to mass.
