Ducato (type 250) Facelift
ducgh
Post by ducgh »
I have the following question:
In the list of the SUPPORTED VEHICLES/SYSTEMS I can see, that for the Fiat
Ducato (type 250) Facelift the Tire Pressure Control (TPMS) Schrader (2/3 axle) is not supported.
Is there a chance that this feature will be implemented in the next Version of the “Multiecuscan” program?
The Version 4.8 I have already bought.
Gerd
ducgh
Re: Ducato (type 250) Facelift
Post by ducgh »
Unfortunately, the Ducato Facelift was not included in version 4.8 of Multiecusan.
chrener
Post by chrener »
Hi!
In MES is 3 versions of Ducato
1 - X250 2006-2009 with white BCM - without adapters
2 - X250FL (means facelift) 2010-2014 same body as X250 but with black BCM - with yellow adapter
3 - X290 body facelift 2014+ with black BCM - with yellow adapter
Newest ducato8 or X295 2021+ is unsupported yet but you can connect to BCM as Fiat TIPO... Proxialignment procedure is on your own risk...
ducgh
Post by ducgh »
Hallo Chrener, many thanks for your hint.
But with my equipment I can’t access to Tipo. I have MES 4.9, EML 327 Interface and the yellow adapter.
Furthermore I wanted to change the value in the Tire Pressure Control and in the list of supported vehicles in non Tipo with a Tire Pressure Control.
nirvananils
Post by nirvananils »
I have actually same problem, with MES 4.9 and CANtieCar don't have access to a Ducato (with Pössl Caravan) ECU's.
On our Fiat 500e (California) everything is working fine
john
Post by john »
chrener wrote: 16 May 2022, 11:20 Hi!
I have the same issue. I can connect to the BCM with AlfaOBD (without adapters) but not to other devices. Using MES SCAN, I can see some devices and also the BCM without adapters. With the yellow adapter I only see SAGEM Power Steering. I can connect to none with MES. I also have some model 2021 before the Ducato 8 was released. I thought about testing with the gray adapter. @chrener any update on your usage?
john
Post by john »
I got a little more information, it seems to be marketed internally as X295, Fiat Ducato MY2020. A bit frustrating that there is no information on the internet. I have no SGW installed. I found an alarm system which can be installed using an OBD adapter but for the Fiat Ducato MY2020, there is some custom adaption necessary, cf. https://www.campinglanghans.de/media/pdf/8a/55/d0/47490_einbauanleitung_1.pdf.
To me it seems that this particular model, shortly before the transition to Series 8 was made, has some yet to be explored changes regarding OBD and how systems can be read out.
john
Post by john »
Anyway, MES worked as expected. There was a wiring error in the CAN BUS. Three wires were linked to mass.
