Uconnect dab activation possible?
JDalfa
Post by JDalfa »
Hi there,
I just bought a tipo with Uconnect 7.0 with tomtom navi and carplay.
It only doesn’t have DAB+.
Is is possible to retrofit this or does it only need activation?
Anyone who can help me, or do it for me in the netherlands?
Kind regards Joost
Re: Uconnect dab activation possible?
radio needs to support DAB, have DAB connector at the back and car should have DAB wiring for aerial. check label on radio - it should say if it supports DAB or not
abarthmultijet
Post by abarthmultijet »
If the radio has a DAB connector on the back it can be activated. You can buy a genuine dab reciever from ebay or amazon.
When you want to activate the DAB function on the radio you have to change bit 123 to D5 and perform a proxy allignment.
JDalfa
Post by JDalfa »
Ok thank you for the replies!
I will check soon if de radio has de dab connector, from what i read this schould be the grey one right?
Is that the only byte to be changed?
you can try to enable it and run proxi. from experience if radio doesn't support DAB it will fail proxi alignment.
as mentioned above it's activated in byte 123. set bit 2 to "1"
abarthmultijet
JDalfa wrote: 30 Nov 2021, 19:13 Is that the only byte to be changed?
Should be, let me know if it has worked or not, maybe i can help you further if it doesn't work.
JDalfa
Post by JDalfa »
Sent you a pm
abarthmultijet
I've gotten your PM, but i don't know for sure you got my message back, the messages stay in the outbox and not in the "send messages" tab
