Fiat 500e radio replacement Proxi failure
Vince
Post by Vince »
I replaced the factory radio in my 2017 Fiat 500e with another factory radio of the same part number. When I checked the proxi alignment screen it showed that the FM2 radio is present and DAB radio not present. In the CAN setup screen it shows Entertainment Telematic Node (ETM) Added/EOL Failed. When I try to do a proxi alignment I get a "ETM Failed Request out of range error message" and the mileage started flashing. The volume controls on the steering wheel will not control the radio, but the dash does show the time set on the radio. All the functions on the radio work but the GPS. Any suggestion on how I can get through this proxi alignment?
Vince
Re: Fiat 500e radio replacement Proxi failure
if P/N are same it shouldn't cause a problem. have you compared labels on radio?
post your FESLog - maybe there are more values which aren't supported by new radio.
also could just try do proxi couple more times - this sometimes helps too.
kisser
Post by kisser »
Is the car from after start 2018 ???? If yes do you have a SGW bypass box ?????
alex-et3
Post by alex-et3 »
try to do the proxy alignment with another diagnostic tester.If the radio is the same it must work.The american 500e has no sgw
Fiat500e
Post by Fiat500e »
Hey Vince,
did you solve the problem?
If not, try this:
Immediately after the failed alignment click "disconnect" at the bottom of the Adjustments tab.
Then click on the PDF Icon on the page with the "Proxi Alignment Procedure (models with Uconnect)" Option.
This will produce a PDF file that at the bottom will tell you why the ETM failed to proxy align and what hex values are wrong.
Go back into your Custom PROXI window and change those values to what the PDF tells you to and hit "ok" and execute the proxy alignment again.
This worked for me.
ariasad@gmail.com
Post by ariasad@gmail.com »
I hope you could help me as well....
I have replaced the original Radio on my Fit 500 S with an aftermarket Stereo. My odometer started flashing so I decided to do PROXI Alignment using MultiECuscan. V4.7 R
In the information page I can see : Receiver Radio (NRR) : EOL Failed. And When I move into Adjustment page and click on Execute button, It cannot write data on Receiver Radio NRR
...FAILD - Timeout Error. All other sections showing SUCCESS during proxy alignment.
I connected to body computer and found B10AA-4A - PROXI configuration Control error is there , which does not go away even if I clear it.
Any ideas how to get rid of this error and have the Proxy Alignment completed successfully ?
thank you !
Aria
FYI the B10AA-4A Error is:
Check Configuration Failed - Incorrect component installed B10AA-4A
Proxy alignment procedure not performed correctly
Perform the Proxy alignment procedure
This error will/should go away when you get a good Proxi Alignment
can500e
Post by can500e »
s130 wrote: 30 Nov 2021, 07:37 FYI the B10AA-4A Error is:
What's a "GOOD" PROXY ALIGNMENT?
When searching PROXY ALIGNMENT for a Fiat 500e this post and forum are always shown at the top of the search page, so for anyone looking for an PROXY ALIGNMENT I will post what worked for me here:
I recently changed the radio from a UCONNECT 5" to a UCONNECT 7" for its Apple CarPlay capabilities. After installing it and determining the radio code none of the radio features worked. With no CarPlay and with an annoying odometer blinking I needed to perform a PROXY ALIGNMENT. PROXY ALIMENT is well documented in the forum (see link - find the pdf attachment).
WORKING PROXI – WITH UCONNECT 7” APPLE CARPLAY ANDRIOD AUTO FOR 500e
31 36 31 32 30 31 35 36 31 30 30 31 32 33 34 35 36 37 38 39 30 20 16 01 21 4D 84 40 05 13 00 02 00 09 00 00 00 03 00 00 00 80 D0 4D 06 F4 40 01 70 0A 01 00 67 00 09 00 94 00 00 04 00 01 A0 10 00 00 00 00 00 00 00 00 00 27 00 00 00 00 35 06 C1 01 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 90 18 52 30 00 D0 02 00 30 00 00 00 44 00 91 00 00 00 00 00 00 01 00 A0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 45 00 00 00 00 00 00 00 00 05 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
TOTAL BYTES 193
This worked and removed the blinking odometer. This also made Apple CarPlay and Android Auto work. It also made the USB recognize the phone. I should mention here that Andrea from the forum https://www.goingelectric.de/forum/viewtopic.php?f=237&t=54795 made this project possible, thank you Andrea.
rodspower
Post by rodspower »
can500e wrote: 22 Jul 2024, 00:10
TOTAL BYTES 193
I`m facing similar issue. I have a 2017 Fiat 500 USA and change from UCONNECT 5" to a UCONNECT 7" , After going to a custom proxy everything works , AppleCarPlay, Android Auto , Steering wheels buttons, but I really don't know why my
odometer is still blinking. The fun fact that multiecu is telling that "WARNING: This vehicle is properly configured. PROXI Alignment is not needed!" .
Looking for DTC's,
Body Computer Delphi (312) MY12
ISO Code: 40 83 EC 8A 0E
VIN code: 3C3AFFARXHT621090
Hardware number: P500L2EU304 - Ver: 03
Software number: 28486828 - Ver: 0702
Errors found:
B10AA-4A - PROXI configuration control - Incorrect component installed
Dashboard / ETM (Entertainment Telematic Module)
Uconnect Radio/Nav 7"
ISO Code: 00 24 70 55 15
Hardware number: F.EU.D8.V28 - Ver: 28
Software number: 23.03.67.12 - Ver: 2303
Errors found:
B223B-00 - Incorrect configuration
My current proxy :
31 37 31 36 32 31 30 39 30 30 30 31 32 33 34 35 36 37 38 39 30 20 17 04 29 4F 80 00 04 11 00 00 00 09 00 00 00 11 00 00 00 01 C0 47 06 F4 00 01 70 0A 00 00 96 00 01 00 95 00 12 02 1E 01 00 70 00 00 00 00 00 00 00 00 00 45 00 00 00 00 31 06 91 01 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 00 90 18 12 00 00 86 02 00 30 00 00 02 44 00 F1 00 0F 00 00 80 01 01 E0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
193 bytes as well.
Can someone help me to find a "GOOD" proxy alignment?
