Hi All,
because I have problems to connect with my Chinese ELM 327 V1,5 (I know, It's a Clone) I want to ask, which cable you recommend ?
I got now two Chinese products (1.3 and 1.5), but with none of them I am able to connect to my 2003er Stilo 1.6. Or is there a trick to modify them?
Thanks for you help...
Kay
Which ELM Cable?
Re: Which ELM Cable?
did you try any other software?
did you receive a cd with driver and softwares? did you install anything?
Hello mate , ELM 327 1.5 is Fake !!!!!
I am recommend this ELM 327 1.3
Thanks.
Thanks.
Yes, I have tried other SW too without success. Also I have received a CD with the driver.
I have changed the Settings like written in many posts here and tried all Baud Rates. Sometimes I get an Errormessage "Connection to ELM failed" Sometimes "Timeout Error".
PS. Which 1.3 Cable do you advise?
Did your received the "Scantool_net113win" software with your interface?kayman55 wrote:Yes, I have tried other SW too without success. Also I have received a CD with the driver.
Yes I've got this SW on the Driver CD...alfa156sarajevo wrote: Did your received the "Scantool_net113win" software with your interface?
did you try to install this software on your computer? and
did you try to connect your stilo with this software?
it should work because this software is very simple but unfortunately not very good.
if both interfaces working with this software than it should work with FES software!!!
