Which ELM Cable?
kayman55
Which ELM Cable?
Post by kayman55 »
Hi All,
because I have problems to connect with my Chinese ELM 327 V1,5 (I know, It's a Clone) I want to ask, which cable you recommend ?
I got now two Chinese products (1.3 and 1.5), but with none of them I am able to connect to my 2003er Stilo 1.6. Or is there a trick to modify them?
Thanks for you help...
Kay
EnIgMa
Re: Which ELM Cable?
Post by EnIgMa »
did you try any other software?
did you receive a cd with driver and softwares? did you install anything?
jony
Post by jony »
Hello mate , ELM 327 1.5 is Fake !!!!!
I am recommend this ELM 327 1.3
Thanks.
kayman55
Post by kayman55 »
Yes, I have tried other SW too without success. Also I have received a CD with the driver.
I have changed the Settings like written in many posts here and tried all Baud Rates. Sometimes I get an Errormessage "Connection to ELM failed" Sometimes "Timeout Error".
PS. Which 1.3 Cable do you advise?
Jerry 159
Post by Jerry 159 »
kayman55 wrote:Yes, I have tried other SW too without success. Also I have received a CD with the driver.
Did your received the "Scantool_net113win" software with your interface?
kayman55
Post by kayman55 »
alfa156sarajevo wrote: Did your received the "Scantool_net113win" software with your interface?
Yes I've got this SW on the Driver CD...
did you try to install this software on your computer? and
did you try to connect your stilo with this software?
it should work because this software is very simple but unfortunately not very good.
if both interfaces working with this software than it should work with FES software!!!
