C1212-55 Help
dincsoy16
C1212-55 Help
Post by dincsoy16 »
I had a different body computer in my car before, and I changed it to aath punto. but abs esp doesn't work and i get c1212-55 error. How can I fix this guys? can you help me?
Custom proxy
33 38 31 39 39 30 32 35 39 38 38 4F 55 54 50 55 54 2D 4A 49 54 20 10 06 11 4F 84 00 05 02 00 00 00 09 04 00 04 02 00 00 00 BA EO 75 07 67 00 2A 21 B3 00 00 OE 00 05 00 94 06 19 01 1E 00 01 00 00 79 40 OA 04 00 00 00 00 21 00 00 00 00 31 1A D1 01 28 00 00
Re: C1212-55 Help
Well all I can say is that error code is:
Control unit EPB section - PROXI configuration – NOT configured OR Proxy data contains values “invalid” or not correct
EPB = ABS and Electric Parking Brake
Does your car have an electric parking brake?
Re: C1212-55 Help
what car is your car? engine, year? what car body computer comes from?
is this proxi from new body ECU or your's?
crowbar99
Re: C1212-55 Help
Post by crowbar99 »
SOLVED!!!
well--- my findings are --- there is configuration fault with MES.
ABS is either looking for torque value OR this C1212-55 is a configuration error code (general purpose)
set vehicle type to non-spark ignition engine and do proxi-alignment--- see if this resolves.
my particular vehicle is Chrysler Ypsilon 1.2 8v
I noticed default setting in engine type waS 1.3MULTIJET
i CHANGED THIS TI 1.2 8V ; DID PROXI-ALIGNMENT and ABS light came on after reset.
(of course diesels to not have ignition system)
changed back to 1.3 multijet and ABS light out-----
Go figure eh!???!
took 3 days to resolve--- going back thru old logs etc.
