what do you think about a topic related to the elm device?
The "VAG KKL cable connections" topic is really helpful, so maybe we can do the same for elm device and stick them.
I thought about it just few minutes ago, after i opened my elm device for solder pins 1-3-7.
I did it on my vag cable with success, but this time a lot of pins are already soldered.
You can see a picture here of it:
So, do i still have to solder pins 1 and 3 to 7? (right now i don't need to connect to airbags ecu).
Then, i read this on another topic:
could be useful to solder pins 11-12-13 too? or at least pin 11 besides 1 and 3? maybe for a future feature?mihaitza83 wrote:if you haven't got an answer by now then alow me:
pin 1. abs
pin 2. unused for the moment
pin 3. airbag (srs)
pin 4 and 5 are for ground -
pin 6. Can High (ELM 327 v1.3)
pin 7. engine
pin 8, immobilizer
pin 9. electronic systems connected to dashboard cable
pin 10. bus + line
pin 11. Electric Steering (alarm, radiofrequenti receiver)
pin 12. electronic systems k lines connected to engine compartiment cable
pin 13. electronic systems k lines connected to rear cable
pin 14. Low Can (ELM 327 v1.3)
pin 15. L line
pin 16. battery power +
Thank you very much.
