ECU detection issue
mikocho
ECU detection issue
Post by mikocho »
Hi everyone,
I have a Fiat Cinquecento MY93 900ie with a Magneti Marelli ECU Ref : IAW 6F.S0/1619-57
I can't connect the ECU to Multiecuscan because I have this error message :
(Multiecuscan 4.7)
27/12/2020 15:10:50
Fiat Cinquecento i.e.
Magneti Marelli IAW 06F Evoluta Injection (ECO)
ECU ISO code: B0 80 AB 91 C1
Spare part number:
WARNING: Unknown ISO code. Module cannot be identified!
I use KKL cable and 3pin adaptator. They are correctly recognized by the software.
I suppose my ECU isn't in the Multiecuscan database right ?
Re: ECU detection issue
The only Cinquecento listed items that MES supports are:
Magneti Marelli IAW 06F Evoluta Injection (ECO) |INFO|DTC|PRM|ACT| KL 3-Pin
Magneti Marelli IAW 06F Injection |INFO|DTC|PRM|ACT| KL 3-Pin
Magneti Marelli IAW 16F Injection |INFO|DTC|PRM|ACT| KL 3-Pin
Suggest you look at the Supported Vehicles List (http://www.multiecuscan.net/SupportedVehiclesList.aspx) and search on 6F looking for IAW 6F or IAW 06F. You will find that the Panda and Siecento models use similar ECUs do try to connect by selecting these models (all versions 900cc, 1000cc etc) as one of these may have the same ISO code as your ECU.
mikocho
Post by mikocho »
Hi everyone,
I succeed to use MES. I didn't tighten very well the battery lug :)
Thanks for your help.
Nicolas
Great. Thank you for letting us know.
