My 2020 Ducato Euro6d 180bhp ISO Codes
RoloPolo
Post by RoloPolo »
Hi all
These two codes are not recognised on the latest version (uninstalled back to my previous licensed version so I can do basic adjustments)
Will purchase new license once vans recognised
Engine/ecm 0001 50 6A 16 unknown/ unsupported
ABS etc
Unknown unsupported
0006 50 65 16
MY 2020 Ducato L4 H3 manual 2.3 180 euro 6d (adblu)
Cheers
Grayducato
Re: My 2020 Ducato Euro6d 180bhp ISO Codes
Post by Grayducato »
Hi Rolopolo
I have just registered as a new user, and have the same problem as you had. I'm not sure if you are still in the forum, but I need a solution. My vehicle is a Ducato 2.3 series 7 2021 build, euro 6D 9 speed auto with Adblue.
I get an ECU not recognised message when I start MES, but all other modules connect OK. My vehicle has been into a Fiat workshop for PM sensor replacement and it was during this time that the ECU was flashed to accommodate the new (Bosch) sensor. This caused a change in the ECU ISO identifier.
I hope you can help, it has been a while since you posted. Do you know how often MES updates their vehicle ISO database?
abarthmultijet
Post by abarthmultijet »
Probally will be in the next MES version, new versions come out sometimes in half a year and sometimes a year. You can check the history here: https://www.multiecuscan.net/ReleaseHistory.aspx
Grayducato
Thank you, Abarthmultijet, the link you posted to the MES update history is excellent. It shows an active updates cycle with unknown ISO codes being added with each release.
I only have the Demo version of 5.3 and would like to see this resolved before I purchase.
Do I need to inform MES of my ISO code to include in a future release? or will MES already have a full list of codes to be added?
How would I inform MES if that is necessary?
Cheers
Send an Email to support@multiecuscan.net quoting your vehicle, ECU and ISO code.
I don't know how they get new/updated ISO codes so dropping them an EMail will do not harm.
Grayducato
Thanks s130,
I did that yesterday after advice from other forum members also, I appreciate your reply too, I can but hope...
Cheers,
Graham in Au :D
