Ducato x250 2.3 mjet external temperature sensor
eismann
Post by eismann »
I've a 2008 Ducato x250 2.3 mjet 120hp, I installed the outside temperature sensor, and i need to activate CAN net to show value on dashboard.
I see, on body-CAN setup no choice to activate ext temp sensor.....but i see in Fiat IDEA body-CAN setup, is present choice to acivate ext temp sensor....whereas the dashboard is the same with ducato, is possible to activate sensor with fiat idea module but on ducato? Thanks!!
eismann
Re: Ducato x250 2.3 mjet external temperature sensor
Post by eismann »
So..... i've been activated external temperature sensor on ducato, using Fiat Idea proxi protocols, with sucess!
gregpawley
Post by gregpawley »
Hi, I'm keen to do this mod on my 2015 x290, can you share how you completed this?
Kumpe
Post by Kumpe »
could you please tell which sensor you installed; where did you pin the sensor?
Many Thanks
Joachim
