I've a 2008 Ducato x250 2.3 mjet 120hp, I installed the outside temperature sensor, and i need to activate CAN net to show value on dashboard.
I see, on body-CAN setup no choice to activate ext temp sensor.....but i see in Fiat IDEA body-CAN setup, is present choice to acivate ext temp sensor....whereas the dashboard is the same with ducato, is possible to activate sensor with fiat idea module but on ducato? Thanks!!
Ducato x250 2.3 mjet external temperature sensor
Re: Ducato x250 2.3 mjet external temperature sensor
So..... i've been activated external temperature sensor on ducato, using Fiat Idea proxi protocols, with sucess!
Hi, I'm keen to do this mod on my 2015 x290, can you share how you completed this?
could you please tell which sensor you installed; where did you pin the sensor?
Many Thanks
Joachim
Many Thanks
Joachim
