Tipo Car Play Proxi
malzapl
Tipo Car Play Proxi
Post by malzapl »
7 '' uconnect live with navi
Dashboard / ETM (Entertainment Telematic Module)
Uconnect Radio/Nav 5"
ISO Code: 00 24 70 54 15
Hi, I have a problem with writing to the proxi configuration, after changing the proxi configuration, I choose "execute" , everything is fine until I connect the blue adapter,
then an error occurs Writing to module: (ETM) FAILED! - Request out of range error
FAILED TO EXECUTE
(ETM) FAILED! - Request out of range error and in body
READING ERROR CODES:
1. B10AA-4A - Sterowanie konfiguracji PROXI
jackthenight
Re: Tipo Car Play Proxi
Post by jackthenight »
I have the same problem with Uconnect 5" in Tipo 2015 1.4 16V.
All ECUs wrote Proxi, but ETM shows error FAILED! - Request out of range error
And Uconnect have error : B222C , because MES 4.4 can't write property Proxi.
Odczyt danych konfiguracyjnych CAN ...
CAN CONFIGURATION DATA:
4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00
33 36 33 35 36 30 30 32 32 35 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 A5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00
Komputer nadwozia (BCM/NBC)
Węzeł sterowania silnika (ECM/NCM)
Węzeł wspomagania elektrycznego (EPS/NGE)
Deska rozdzielcza (IPC/NQS)
Węzeł układu hamulcowego (ABS/BSM/NFR)
Węzeł czujnika parkowania (PAM/NSP)
Węzeł poduszek powietrznych (NAB/ORC)
Węzeł klimatyzacji (HVAC/NCL)
Węzeł rozrywkowo-telematyczny (ETM)
(Multiecuscan 4.4)
2019-04-06 19:53:16
Fiat Tipo 2015 1.4 16V
CAN Setup / PROXI Alignment Procedure (356)
Komputer nadwozia (BCM/NBC): EOL Ok
Węzeł sterowania silnika (ECM/NCM): EOL Ok
Węzeł wspomagania elektrycznego (EPS/NGE): EOL Ok
Deska rozdzielcza (IPC/NQS): EOL Ok
Węzeł układu hamulcowego (ABS/BSM/NFR): EOL Ok
Węzeł czujnika parkowania (PAM/NSP): EOL Ok
Węzeł poduszek powietrznych (NAB/ORC): EOL Ok
Węzeł klimatyzacji (HVAC/NCL): EOL Ok
Węzeł rozrywkowo-telematyczny (ETM): EOL Ok
UWAGA: Pojazd jest właściwie skonfigurowany. Nastawy PROXI nie są wymagane!
AKTYWOWANIE REGULACJI...
PROCEDURA 'OSIOWANIA' PROXI
Zapis danych konfiguracyjnych CAN ...
Zapis do modułu: Komputer nadwozia (BCM/NBC) UDANY!
Zapis do modułu: Węzeł sterowania silnika (ECM/NCM) UDANY!
Zapis do modułu: Węzeł wspomagania elektrycznego (EPS/NGE) UDANY!
Zapis do modułu: Deska rozdzielcza (IPC/NQS) UDANY!
Zapis do modułu: Węzeł układu hamulcowego (ABS/BSM/NFR) UDANY!
Zapis do modułu: Węzeł czujnika parkowania (PAM/NSP) UDANY!
Zapis do modułu: Węzeł poduszek powietrznych (NAB/ORC) UDANY!
Zapis do modułu: Węzeł klimatyzacji (HVAC/NCL) UDANY!
Zapis do modułu: Węzeł rozrywkowo-telematyczny (ETM) NIEUDANY! - Błąd: żądanie spoza zakresu ( FAILED! - Request out of range error)
WYKONANIE NIEUDANE
Apocalypto
Post by Apocalypto »
malzapl I know the solution to our problem.
As your proxi, this string, ends with 160 or even fewer bytes, then add 00 00 00 00 00 until there are 235 bytes.
Then all computers will accept this proxi, ecu radio also.
My factory proxi looks like this:
33 36 33 35 36 30 30 32 32 35 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 A5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00
So that the radio will play them, you should change them so that it has 235 bytes, that is:
33 36 33 35 36 30 31 31 36 32 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 B5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
And in Polish, because I can see from the messes logs that you are from Poland:
Znam rozwiązanie naszego problemu.
Jak twoje proxi , ten ciąg znaków, kończy się na 160 czy nawet mniej bajtach, to należy dopisać 00 00 00 00 00 aż będzie bajtów 235.
Wtedy wszystkie komputery przyjmą to proxi, ecu radia również.
Moje fabryczne proxi wygląda tak :
To żeby radio je wgrało należy je zmenić na takie, aby miało 235 bajtów, czyli :
33 36 33 35 36 30 31 31 36 32 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 B5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Pozdrawiam
naibaf91
Post by naibaf91 »
So the solution works also for any Problems with proxy in Radio ecu? I have change the uconnect 7, my old device is brocken, when i try proxy i became the same error.
