7 '' uconnect live with navi
Dashboard / ETM (Entertainment Telematic Module)
Uconnect Radio/Nav 5"
ISO Code: 00 24 70 54 15
Hi, I have a problem with writing to the proxi configuration, after changing the proxi configuration, I choose "execute" , everything is fine until I connect the blue adapter,
then an error occurs Writing to module: (ETM) FAILED! - Request out of range error
FAILED TO EXECUTE
(ETM) FAILED! - Request out of range error and in body
READING ERROR CODES:
1. B10AA-4A - Sterowanie konfiguracji PROXI
Tipo Car Play Proxi
Re: Tipo Car Play Proxi
I have the same problem with Uconnect 5" in Tipo 2015 1.4 16V.
All ECUs wrote Proxi, but ETM shows error FAILED! - Request out of range error
And Uconnect have error : B222C , because MES 4.4 can't write property Proxi.
Odczyt danych konfiguracyjnych CAN ...
CAN CONFIGURATION DATA:
4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00
33 36 33 35 36 30 30 32 32 35 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 A5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00
Komputer nadwozia (BCM/NBC)
Węzeł sterowania silnika (ECM/NCM)
Węzeł wspomagania elektrycznego (EPS/NGE)
Deska rozdzielcza (IPC/NQS)
Węzeł układu hamulcowego (ABS/BSM/NFR)
Węzeł czujnika parkowania (PAM/NSP)
Węzeł poduszek powietrznych (NAB/ORC)
Węzeł klimatyzacji (HVAC/NCL)
Węzeł rozrywkowo-telematyczny (ETM)
(Multiecuscan 4.4)
2019-04-06 19:53:16
Fiat Tipo 2015 1.4 16V
CAN Setup / PROXI Alignment Procedure (356)
Komputer nadwozia (BCM/NBC): EOL Ok
Węzeł sterowania silnika (ECM/NCM): EOL Ok
Węzeł wspomagania elektrycznego (EPS/NGE): EOL Ok
Deska rozdzielcza (IPC/NQS): EOL Ok
Węzeł układu hamulcowego (ABS/BSM/NFR): EOL Ok
Węzeł czujnika parkowania (PAM/NSP): EOL Ok
Węzeł poduszek powietrznych (NAB/ORC): EOL Ok
Węzeł klimatyzacji (HVAC/NCL): EOL Ok
Węzeł rozrywkowo-telematyczny (ETM): EOL Ok
UWAGA: Pojazd jest właściwie skonfigurowany. Nastawy PROXI nie są wymagane!
AKTYWOWANIE REGULACJI...
PROCEDURA 'OSIOWANIA' PROXI
Zapis danych konfiguracyjnych CAN ...
Zapis do modułu: Komputer nadwozia (BCM/NBC) UDANY!
Zapis do modułu: Węzeł sterowania silnika (ECM/NCM) UDANY!
Zapis do modułu: Węzeł wspomagania elektrycznego (EPS/NGE) UDANY!
Zapis do modułu: Deska rozdzielcza (IPC/NQS) UDANY!
Zapis do modułu: Węzeł układu hamulcowego (ABS/BSM/NFR) UDANY!
Zapis do modułu: Węzeł czujnika parkowania (PAM/NSP) UDANY!
Zapis do modułu: Węzeł poduszek powietrznych (NAB/ORC) UDANY!
Zapis do modułu: Węzeł klimatyzacji (HVAC/NCL) UDANY!
Zapis do modułu: Węzeł rozrywkowo-telematyczny (ETM) NIEUDANY! - Błąd: żądanie spoza zakresu ( FAILED! - Request out of range error)
WYKONANIE NIEUDANE
(Multiecuscan 4.4)
2019-04-06 19:53:16
WYKONANIE NIEUDANE
malzapl I know the solution to our problem.
As your proxi, this string, ends with 160 or even fewer bytes, then add 00 00 00 00 00 until there are 235 bytes.
Then all computers will accept this proxi, ecu radio also.
My factory proxi looks like this:
Znam rozwiązanie naszego problemu.
Jak twoje proxi , ten ciąg znaków, kończy się na 160 czy nawet mniej bajtach, to należy dopisać 00 00 00 00 00 aż będzie bajtów 235.
Wtedy wszystkie komputery przyjmą to proxi, ecu radia również.
Moje fabryczne proxi wygląda tak :
So that the radio will play them, you should change them so that it has 235 bytes, that is:33 36 33 35 36 30 30 32 32 35 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 A5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00
And in Polish, because I can see from the messes logs that you are from Poland:33 36 33 35 36 30 31 31 36 32 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 B5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
To żeby radio je wgrało należy je zmenić na takie, aby miało 235 bajtów, czyli :33 36 33 35 36 30 30 32 32 35 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 A5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00
Pozdrawiam33 36 33 35 36 30 31 31 36 32 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 B5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
So the solution works also for any Problems with proxy in Radio ecu? I have change the uconnect 7, my old device is brocken, when i try proxy i became the same error.
