Fiat ECU documentation
I have some Fiat technical ECU documents in pdf format that might be of interest. However, the "upload attachment" facility will not accept filetype pdf. Is there a way I can share them?
blackfish
blackfish
Re: Uploading files
I allowed .pdf attachments now. You can try again.
Re: Uploading files
hi,
witch docs have you ?
regards
regards
Re: Fiat ECU documentation
Here are the first two files. Two more to follow.
blackfish
blackfish
The other two files:
blackfish
blackfish
Re: Fiat ECU files
fiat ecu file iaw16f
good luck with file
greets wilco1v
good luck with file
greets wilco1v
fiat-W-M-iaw16f.pdf- (388.49 KiB) Downloaded 2447 times
Re: Fiat ECU files
D2401_fiat_hitachi_mpi.pdf- Fiat Hitachi MPI
- (1.04 MiB) Downloaded 1609 times
Re: Fiat ECU files
Any chance someone has documentation for the older non-bosch ECUs used on alfa 8V boxer engines in the 145/146?
Do you know the ECU type or number?
Do anyone knows the protocol used by the Bosch Motronic MA1.7.3 ECU?
I'm developing a ECU scanner for a university project on a Fiat Marea 1.4 12V and i'm not being succesfull so far.
Thank you in advance
Roniconi
Roniconi
