Fiat ECU documentation
blackfish
Post by blackfish »
I have some Fiat technical ECU documents in pdf format that might be of interest. However, the "upload attachment" facility will not accept filetype pdf. Is there a way I can share them?
blackfish
Re: Uploading files
I allowed .pdf attachments now. You can try again.
jpl250rs
Re: Uploading files
Post by jpl250rs »
hi,
witch docs have you ?
regards
blackfish
Re: Fiat ECU documentation
Post by blackfish »
Here are the first two files. Two more to follow.
07234 General diagnosis specification.pdf
(366.67 KiB) Downloaded 2753 times
07273 Diagnostic protocol standard Fiat 9141.pdf
(252.4 KiB) Downloaded 2284 times
blackfish
blackfish
Post by blackfish »
The other two files:
07274 Fiat standard diagnostic protocol on CAN.pdf
(591.98 KiB) Downloaded 1892 times
blackfish
wilco1v
Re: Fiat ECU files
Post by wilco1v »
fiat ecu file iaw16f
good luck with file
greets wilco1v
fiat-W-M-iaw16f.pdf
(388.49 KiB) Downloaded 2176 times
lorand
Re: Fiat ECU files
Post by lorand »
D2401_fiat_hitachi_mpi.pdf
Fiat Hitachi MPI
(1.04 MiB) Downloaded 1335 times
WhizzMan
Re: Fiat ECU files
Post by WhizzMan »
Any chance someone has documentation for the older non-bosch ECUs used on alfa 8V boxer engines in the 145/146?
blackfish
Post by blackfish »
Do you know the ECU type or number?
roniconi
Post by roniconi »
Do anyone knows the protocol used by the Bosch Motronic MA1.7.3 ECU?
I'm developing a ECU scanner for a university project on a Fiat Marea 1.4 12V and i'm not being succesfull so far. :(
Thank you in advance
Roniconi
