I have been using my ELM cable on my 159 for some time now
Now my wife has a 2012 Panda twinair 85pk.
The voltage on de ECU reads 0.4 volt in Mulitecuscan, but I have 12 V (off) and 14V (running) on the battery poles.
Ecuscan says it measures on the ECU, but 0.4V can't be right as the ECU does not run on that voltage.
Is this a ecuscan bug or a major problem with the Panda.
Panda 2012 0.9 twinair turbo voltage bug ?
Re: Panda 2012 0.9 twinair turbo voltage bug ?
Any update on what seems to be multiecuscan reading the wrong value. 0.5V is no normal voltage to run the ECU on.
I see that it's the best one.
Scanned our Panda 2012 Twinair.
0.5v here also.
0.5v here also.
Good to know that it also happens on other Panda's. The question now if it is a ecuscan bug or a bug in the Panda motor management.
