Panda 2012 0.9 twinair turbo voltage bug ?
eelco74
Post by eelco74 »
I have been using my ELM cable on my 159 for some time now
Now my wife has a 2012 Panda twinair 85pk.
The voltage on de ECU reads 0.4 volt in Mulitecuscan, but I have 12 V (off) and 14V (running) on the battery poles.
Ecuscan says it measures on the ECU, but 0.4V can't be right as the ECU does not run on that voltage.
Is this a ecuscan bug or a major problem with the Panda.
eelco74
Re: Panda 2012 0.9 twinair turbo voltage bug ?
Post by eelco74 »
Any update on what seems to be multiecuscan reading the wrong value. 0.5V is no normal voltage to run the ECU on.
Takuihura
Post by Takuihura »
I see that it's the best one.
Vic20
Post by Vic20 »
Scanned our Panda 2012 Twinair.
0.5v here also.
eelco74
Post by eelco74 »
Good to know that it also happens on other Panda's. The question now if it is a ecuscan bug or a bug in the Panda motor management.
