Hi all.
I was trying to do a proxy alignment on my 147 GTA 03, but it will not connect to dashboard node. When I try to connect directly to the dash nodes i get error "elm327 - ecu com fail."
Any Ideas? everything is working as it should on the dash and car. And yes I do have full version of multiecuscan 1.8.
Thanks!
Here is the log for proxy alignment:
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
0
0
0
0
0
0
Writing to module: Dashboard Node (NQS) FAILED! - Timeout error
Writing to module: Driver Door Node (NPG) SUCCESS!
Writing to module: Climate Control Node (NCL) SUCCESS!
FAILED TO EXECUTE
Alfa 147 GTA, unable to connect to dash.
Re: Alfa 147 GTA, unable to connect to dash.
I have exactly the same problem, and I'm not even able to connect to the dashboard (VDO).
Any news?
I'm using a straight ELM327 cable, and everything else is working fine.
Alfa 147 2.0 Selespeed
Any news?
Solved, tried several days after to connect to dashboard and it was succesfull!
Now even the proxi alignement is ok with all modules registerd to the BC!
Back to the problem, I'm not able to connect to dashboard and subsequently to carry out a proxy alignment.
Cable used is an Elm327 v1.4
All Ecu's are read in test mode, and it can connect to everything other than dashboard, service reset.
