Hi All,
I just ran the proxi alignment procedure on a Lancia Thesis 2.4 20v because the cd player was exanged. Afterwards we got an EOL error indicated on the dashboard. I´ve got the following report
CAN CONFIGURATION DATA:
00 02 F7 5B 00 02 F7 5B 00 00 44 40 00 00 40 40 00 00 00 00
00 02 F7 5B 00 00 00 09 00 02 F7 5B 00 00 00 09 00 00 00 09
30 31 31 31 35 30 30 30 32 38 37 4F 55 54 50 55 54 2D 4A 49 54 20 02 10 17 5B F7 02 00 09 00 00 00 00 00 03 12 42 00 00 00 00 00 23 50 20
Body Computer Node (NBC)
Engine Control Node (NCM)
Dashboard Node (NQS)
Steering Wheel Controls Node (NVO)
Brake System Node (NFR)
Driver Door Node (NPG)
Boot Node (NVB)
Climate Control Node (NCL)
Steering Angle Sensor Node (NAS)
Parking Brake Control Node (NPB)
Ceiling Node (NIM)
Side Acceler./Yaw Node (NYL)
Passenger Door Node (NPP)
Boot Node (NVB)
Ceiling Node (NIM)
16-4-2013 20:59:00
CONNECTED TO:
Lancia Thesis 2.4 20V
Body Computer Node (NBC):
Engine Control Node (NCM):
Dashboard Node (NQS):
Steering Wheel Controls Node (NVO):
Brake System Node (NFR):
Driver Door Node (NPG):
Boot Node (NVB):
Climate Control Node (NCL):
Steering Angle Sensor Node (NAS):
Parking Brake Control Node (NPB):
Ceiling Node (NIM):
Side Acceler./Yaw Node (NYL):
Passenger Door Node (NPP):
Boot Node (NVB):
Ceiling Node (NIM):
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (NQS) FAILED! - Timeout error
FAILED TO EXECUTE
Any help on what the Dashboard Node is, or what else could be wrong is very much appreciated!!
Thanks in advance!
Lancia Thesis dashboard node (NQS) failure
Re: Lancia Thesis dashboard node (NQS) failure
Anybody a thought on this?
The plan for today is to install another unit, and do the proxi alignment procedure again.
Thanks!!
Thanks!!
Anybody a thought on what the Dashboard node is, and where it is located??
The new cd player unit was installed, now at least it was recognized and connected by the proxi alignment procedure, but still with a failure message on the dashboard node.
Hello!
I have almost the same problem. I used a proxy alighment procedure on my car and now does not recognize the body ECU ABS, ESP, ASR ....
Before applying proxy everything worked normally.
Does anyone have any idea what happened. Use ELM 327 1.5A...
Odometer flashes EOL error. Does anyone have any idea what happened?
The solution is to read the configuration file with the help of other software and interface. File must be edited by the original rigidity configuration read before applying proxi alignment procedure and recorded back in the body computer. The values are stored in the file automatically saved in the folder on your computer Multietsustsan.
The solution always exists... If MES can not do it I am sure official service can do it.
Phaeton_82
Could you please be more specific? Which one is the configuration file? "FES_Tags" or "FES_Templates"? What other software and interface? Thank you very muchalekssina wrote: ↑12 Jan 2014, 17:42 The solution is to read the configuration file with the help of other software and interface. File must be edited by the original rigidity configuration read before applying proxi alignment procedure and recorded back in the body computer. The values are stored in the file automatically saved in the folder on your computer Multietsustsan.
