Lancia Thesis dashboard node (NQS) failure
Keser
Post by Keser »
Hi All,
I just ran the proxi alignment procedure on a Lancia Thesis 2.4 20v because the cd player was exanged. Afterwards we got an EOL error indicated on the dashboard. I´ve got the following report
CAN CONFIGURATION DATA:
00 02 F7 5B 00 02 F7 5B 00 00 44 40 00 00 40 40 00 00 00 00
00 02 F7 5B 00 00 00 09 00 02 F7 5B 00 00 00 09 00 00 00 09
30 31 31 31 35 30 30 30 32 38 37 4F 55 54 50 55 54 2D 4A 49 54 20 02 10 17 5B F7 02 00 09 00 00 00 00 00 03 12 42 00 00 00 00 00 23 50 20
CURRENTLY CONFIGURED CAN MODULES:
Body Computer Node (NBC)
Engine Control Node (NCM)
Dashboard Node (NQS)
Steering Wheel Controls Node (NVO)
Brake System Node (NFR)
Driver Door Node (NPG)
Boot Node (NVB)
Climate Control Node (NCL)
Steering Angle Sensor Node (NAS)
Parking Brake Control Node (NPB)
Ceiling Node (NIM)
Side Acceler./Yaw Node (NYL)
Passenger Door Node (NPP)
CURRENTLY AVAILABLE CAN MODULES:
Boot Node (NVB)
Ceiling Node (NIM)
CAN MODULES THAT REQUIRE EOL PROGRAMMING:
16-4-2013 20:59:00
CONNECTED TO:
Lancia Thesis 2.4 20V
CURRENTLY CONFIGURED CAN MODULES::
Body Computer Node (NBC):
Engine Control Node (NCM):
Dashboard Node (NQS):
Steering Wheel Controls Node (NVO):
Brake System Node (NFR):
Driver Door Node (NPG):
Boot Node (NVB):
Climate Control Node (NCL):
Steering Angle Sensor Node (NAS):
Parking Brake Control Node (NPB):
Ceiling Node (NIM):
Side Acceler./Yaw Node (NYL):
Passenger Door Node (NPP):
CURRENTLY AVAILABLE CAN MODULES::
Boot Node (NVB):
Ceiling Node (NIM):
CAN MODULES THAT REQUIRE EOL PROGRAMMING::
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (NQS) FAILED! - Timeout error
FAILED TO EXECUTE
Any help on what the Dashboard Node is, or what else could be wrong is very much appreciated!!
Thanks in advance!
Keser
Re: Lancia Thesis dashboard node (NQS) failure
Post by Keser »
Anybody a thought on this?
The plan for today is to install another unit, and do the proxi alignment procedure again.
Thanks!!
Keser
Post by Keser »
Anybody a thought on what the Dashboard node is, and where it is located??
The new cd player unit was installed, now at least it was recognized and connected by the proxi alignment procedure, but still with a failure message on the dashboard node.
alekssina
Post by alekssina »
Hello!
I have almost the same problem. I used a proxy alighment procedure on my car and now does not recognize the body ECU ABS, ESP, ASR ....
Before applying proxy everything worked normally.
Does anyone have any idea what happened. Use ELM 327 1.5A...
Odometer flashes EOL error. Does anyone have any idea what happened?
alekssina
Post by alekssina »
The solution is to read the configuration file with the help of other software and interface. File must be edited by the original rigidity configuration read before applying proxi alignment procedure and recorded back in the body computer. The values ​​are stored in the file automatically saved in the folder on your computer Multietsustsan.
The solution always exists... If MES can not do it I am sure official service can do it.
Phaeton_82
Post by Phaeton_82 »
alekssina wrote: 12 Jan 2014, 17:42 The solution is to read the configuration file with the help of other software and interface. File must be edited by the original rigidity configuration read before applying proxi alignment procedure and recorded back in the body computer. The values ​​are stored in the file automatically saved in the folder on your computer Multietsustsan.
Could you please be more specific? Which one is the configuration file? "FES_Tags" or "FES_Templates"? What other software and interface? Thank you very much
