ELM 327 1.4 interface
pac238
Post by pac238 »
hi, this is my first post. i am having problems trying to connect engine ecu. i can connect to body ecu but not engine i keep getting connection error check port setting which i have adjusted lots of times. i have a fiat 500 1.4 which i bought damage ,can anybody help...thanks.
Re: ELM 327 1.4 interface
Hello pac238
The engine control unit you need to directly read
For all other controllers you need an adapter!
http://www.ebay.de/itm/151015670657?ssP ... 1438.l2649
Have you used this?
Otherwise, it can only lie in the settings
Which driver did you use?
pac238
Post by pac238 »
Hi alfaeddy, i have three adapters one yellow,green ,red. i have tried altering the setting in multiecuscan and driver setting but i get 'interface/cable error. i can connect to body ecu but nothing else. if i press simulate i get error code B0110 open circuit/short circuit at +v batt, any idea what this means? ....i used interface drivers from www.idiagnostic.co.uk/drivers/ELM.ZIP... HELP !
Hello pac238
The simulation has nothing to do with the reading of your controls
As the name suggests it is a simulation
This function is only intended to get to know the program
Have you ever tried the connection without adapter to the engine ECU or the ABS?
It's just strange that you can connect to the body and not to other controllers?
If your interface recognized in the Control Panel of Windows without errors?
Otherwise, once try this driver
