yani wrote:About the service reset:
Did you try to change "Service interval" (Lettura intervallo servizi) and "Service period" to lower values? I added these 2 adjustments since Multiecuscan 1.1 to fix the problem with vehicles where the other two adjustments do not work. You may need to execute "NEXT SERVICE KM RESET" and/or turn the key OFF and then back ON after setting the new values.
Ops, I don't have tryed to change "Service Interval" but "distance of next service"! I have resolved whit "service interval", excuse me, works well!
I don't changed the value "Service Period" because this value not appear in the Instrument Cluster, only value showed is remaining km to next service (Service Interval).
yani wrote:About the engine oil change:
This is the correct ECU for your engine. It shouldn't give you Invalid ISO message. There was a bug with some ISO codes in previous versions. Do you use the latest version of Multiecuscan?
Also, what is the value of "Oil change counter"?
I used Multiecuscan 1.1.
Today I installed the last version and Invalid ISO message as disappeared.
I execute again the Adjustments "Oil change (only DPF version)" and "Oil Change Couter" rose from 1.9% to 100%.
Works well!
alfa156sarajevo wrote:Regarding your first part of post from above, I did mentioned few months ago to Yani that on Panda it is not possible to do manual adjustment for option "distance of next oil change".
Since I was working on petrol car for me was just fine service coupon.
I hope it will be possible in near future...
Hi, you tryed "Service Interval" Adjustments? On my Panda works perfectly! The distance next oil change is changed!
Thanks a lot for soonest reply and assistance!
Best Regards!
