hello,
here I would like connected to the airbag computer in my fiat stilo jtd 2003, for this I use a ELM327 change with pin 3 and 1 link. but when connecting I can not put you need a VAGCOM or OBDKEY.
But the site says with ELM327
es that I can then completely disable the airbags in seats because I mounted the seats bacquet
Airbag Fiat stilo JTD with ELM327 modified
Re: Airbag Fiat stilo JTD with ELM327 modified
In the list have all Fiat Stilo one My99 Airbag System
and can only be read with a KKL interface or OBDkey
With your ELM 327 does not come on the control
Yes! Alfaeddy is right!
You need KL interface to connect airbag ECU and your Fiat Stilo...
So what I need cable? have found on the internet?
?? http://cgi.ebay.fr/Interface-USB-VAG-KK ... 231a987ebc
it's good ?
it's good ?
Yes this is the correct cable (KKL interface)
You'll need to have an adapter cable 2 for the airbag control unit
or the interface has to be rebuilt.
Question at this dealer (Mr. Ulbricht) to, he can also provide you the adapter cable.
forgive me my English very bad, I can not be all inclusive.
the refore the KKL cable should however must be the change Rellier to pin 3 and 1 or buy an adapter.
My english is bad
Properly for this KKL you still need the adapter
Adapter 1 = ABS etc.
Adapter 2 = Airbag
Alternatively, it may also be converted so that it works without an adapter.
My english is bad
Adapter 2 = Airbag
