Fiat Bravo headlights switch on
Sev
Post by Sev »
Is it possible to switch on the low beam lights , when the the engine starts?
Re: Fiat Bravo headlights switch on
As far as I know the low beam headlights of all Fiats (and Alfa) work this way.
The low beam switch in my car is always set to ON... The headlights switch on when I start the car (or turn the key to MAR)... and switch OFF when I turn the key to OFF.
Aron96
Post by Aron96 »
Sev wrote:Hello
Hello, your question, but what it refers to, because I can only tell you that starting up the body computer disables the various consumers for a more immediate starter, then immediately after he started the engine and immediately reactivated.
regards
aron96
Hello Yani, I did not want to interfere in a reply can be seen while I was translating a message sent to you
sorry
Sev
Post by Sev »
yes
but in this case running also - front and rear gauges, dashboard lights and the number plate lights
somebody know how is the situation with the Bravos after 2011 ? - they must have Day Lights
Aron96
Post by Aron96 »
As said before start-up turns off everything, then when the light of day they can enable and disable menu board
Sev
Post by Sev »
no such option in dashboard menu
Aron96
Post by Aron96 »
Hello sev, then I'll explain you can only turn on and off the light during the day, instead of the light beam must switch them through the stalk, then I do not know what you mean
Sev
Post by Sev »
in my country the cars must run with DRL/low beam all year long
in Bravo is not possilble to use only the low beam
I think what Sev is trying to say is this.
In his country he has to drive in the day with dipped beam headlights OR Daylight Running Lights.
As he does not have Daylight Running Lights he has to run with dipped headlights.
However with dipped headlights the side lights, number plate lights, dashboard back lighting, etc. etc. are also turned on.
He just wants the dipped headlights and leave all the otherlights OFF.
Aron96
Post by Aron96 »
S130 Hello, you more or less I understand what you're saying but like all who work in cars, we know that you can not disable this feature, settings are required by law. But as already said before we have to see how the preparations are a nation where immatricolti
