Croma 1.9 MJTD EDC16C39 CF4 Oil degradation level: 100.00 %
bas
Post by bas »
I made Oil change
EXECUTING ADJUSTMENT...^M
Wymiana oleju (tylko dla wersji z DPF)^M
WYKONANE^M
and now the Oil degradation level is set to 100.00 %, the oil light on dashboard is blinking.
I checked on 3.3 and 3.4.1.
BAS
Juggers2k
Re: Croma 1.9 MJTD EDC16C39 CF4 Oil degradation level: 100.0
Post by Juggers2k »
On vehicles with a DPF, I believe aswell as the service resets on the instrument cluster, there is a separate oil service function on the engine controller (along with DFP regen etc).
On your Croma there are TWO resets that need to be done. The Service Reset and Oil Change Reset.
The Oil Change Reset is done via the Engine ECU under "F7 Adjustments" control section/tab
bas
Post by bas »
s130 wrote:On your Croma there are TWO resets that need to be done. The Service Reset and Oil Change Reset.
I know it and i made both.
BAS
bas
Post by bas »
Ok, now it's not blinking, i'll monitor this and i'll inform if there is still problem.
BAS
Good to hear.
I am wondering with much of the individual ECU software versions and levels that it takes a shut down/restart of the ECU to correctly report the new state. A shutdown/restart would be a disconnect of the ECU software. A disconnet of the hardware followed by and ignition off/on cycle.
