bas
Posts: 143 Joined: 10 Feb 2010, 21:47
Post
by bas » 31 Jan 2012, 19:37
I made Oil change
EXECUTING ADJUSTMENT...^M
Wymiana oleju (tylko dla wersji z DPF)^M
WYKONANE^M
and now the Oil degradation level is set to 100.00 %, the oil light on dashboard is blinking.
I checked on 3.3 and 3.4.1.
BAS
Juggers2k
Posts: 185 Joined: 17 Jan 2011, 18:02
Post
by Juggers2k » 01 Feb 2012, 09:53
On vehicles with a DPF, I believe aswell as the service resets on the instrument cluster, there is a separate oil service function on the engine controller (along with DFP regen etc).
Posts: 1067 Joined: 20 Jan 2010, 10:07
Post
by s130 » 01 Feb 2012, 10:19
On your Croma there are TWO resets that need to be done. The Service Reset and Oil Change Reset.
The Oil Change Reset is done via the Engine ECU under "F7 Adjustments" control section/tab
bas
Post
by bas » 01 Feb 2012, 10:53
s130 wrote: On your Croma there are TWO resets that need to be done. The Service Reset and Oil Change Reset.
I know it and i made both.
BAS
bas
Post
by bas » 06 Feb 2012, 15:22
Ok, now it's not blinking, i'll monitor this and i'll inform if there is still problem.
BAS
Post
by s130 » 06 Feb 2012, 19:15
Good to hear.
I am wondering with much of the individual ECU software versions and levels that it takes a shut down/restart of the ECU to correctly report the new state. A shutdown/restart would be a disconnect of the ECU software. A disconnet of the hardware followed by and ignition off/on cycle.
